Pontiac 400 Front Cover interchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2007, 07:18 PM
Soon to be Old Fart
Is it possible to use a '67 400 front cover AND balancer on a '73 440?
I know the bolt patterns on the balancer are different (6 vs 4) but I want to transplant the whole assembly.
I am building a '29 A coupe with a 400 so it's a tight squeeze.
I would gain some radiator and crossmember clearance and that would mean a lot less fooling around with motor and trans mounts.
Old 07-02-2007, 09:42 PM
ericnova72's Avatar
More for Less Racer
Pontiac front cover
Not sure what you are talking about, Pontiac never built a 440. 440 is a Chrysler Big Block.
Old 07-03-2007, 07:20 AM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
Pontiac had a 421 engine till about 1966 & a 455 engine in 1973 ...as I remember. Any one of these ring a bell?
Old 07-03-2007, 01:39 PM
WDCreech's Avatar
Grumpy Old Goat Herder
If that was just a typing error and you meant '73 400 the answer is yes. You need to use everything from the front of the '67, such as brackets, spacers, etc.
ID:	22511   Click image for larger version
Old 07-05-2007, 09:15 PM
Soon to be Old Fart
Fat fingers
Thanks guys,
Yeah, I had a case of fat fingers when I typed 440 I meant 400.
I thought every thing would swap but it's been a while since I played with these motors.
I grew up (?) in the "Golden Era" '60 - '72 and I was fortunate to have had a cousin who was a Pontiac dealer. I worked there for a while and had a few old Pontiacs. My favorite was a '61 Catalina Bubble Top with Tri-Power and 8 lugs. We split the floor and put a 4 speed Hydramatic from a Bonneville in it. The factory rep said it couldn't be done. We used Permanent Anti-freeze cans to fill in the gaps. The Permanent ones last longer.
Old 07-05-2007, 10:37 PM
WDCreech's Avatar
I guess it's been a while! Anifreeze comes in plastic jugs, now.
ID:	22550   Click image for larger version
Pontiac 400 build firebird_red Engine 4 11-02-2009 11:05 PM
1986 pontiac acaidian with a pontiac 400 mazmanian Engine 2 07-30-2005 01:35 PM
pontiac 350 vs 400 bb jjweb74 Engine 15 11-12-2004 02:30 PM
68 pontiac timing chain cover lil red rooster Engine 7 11-14-2002 02:34 PM
68 Pontiac 400 for sale drewhelm Engine 3 08-07-2002 08:07 AM
