Pontiac 400 into 85 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2012, 06:05 PM
Hello all rodders. I am putting a 1970 pontiac 400 into my 1985 chevy k10 pickup. The motor mounts on the 400 sit more in the center of the engine, while the mounts on the original 350 are more to the front of the engine. Is there an adapter bracket made for this or will i need to fabricate a mount? Also, will I need a conversion plate to mount to my chevy transmission? Any suggestions will be greatly appreciated. Thanks
Old 11-21-2012, 06:08 PM
Banned User
i think you can use firebird mounts---will try to find the link.
Also, i think you need an adapter plate for the trans and this puts the torque converter about 1/4" further out from the transmission input shaft; i'm not sure how to take care of that issue, if it's even an issue?
Old 11-21-2012, 06:13 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Not familiar with this swap but you might want to look at 2nd gen firebird motor mounts to begin with. It was a vehicle that could be optioned with either a small block chevy or a short deck pontiac v8 in it's later years. Not sure if you'll find your answer there, but it's a place to start.
Wiki Edits: 15
just noticed your post. I'm slow tonight haha.
Old 11-21-2012, 06:18 PM
I think all you would need to do is get a dual pattern tranny. Don't know if there is a TH400 dual pattern or only Th350's I put one of those in my Skylark with a 300 (same bolt pattern as your Pontiac "BOP") to update the trans.
But the Buick Th400's aren't a whole lot of money so you could go with one of those. I put a 455 Buick in a 1978ish Chevy pickup one time, yes motor mounts needed to be built but we used a Buick TH400 and put it right in. From what I remember, but my memory........the drive shaft may have been needed to be modified. But really was a pretty easy swap.
Old 11-21-2012, 07:12 PM
Banned User
Why do you want to do this? i think it would be easier, cheaper, faster to use a chevy engine.
Here is the link anyways:
Pontiac 400 in an '82 GMC truck - PY Online Forums
Old 11-21-2012, 07:22 PM
Wiki Edits: 15
Why wouldn't you want to do this? You can find a lot of factory 400+ cube BOP motors that came ready to rock from the factory. Since we live in this "chevy-centric" world where everything gets swapped for various generations of the SBC, the other brands v8 mills can be found inexpensive because most people think that 350's are the be-all, end-all of performance motors.
- Cameron
Old 11-21-2012, 07:28 PM
Banned User
Well, the reason why i personally would stick with chevy is:
1) It will be much quicker than using an engine that was not originally installed in this chassis; i can install a SBC in a car that originally had one in about 4 hours. It would probably take much longer with, for example, a pontiac v-8 because you would have to hunt down the mounts. The alternator and starter are on opposite sides, so now you got to extend the wires. Yes, i know, not a big deal but it will take more time. Then we got to deal with the trans adapter.
2) It will be cheaper in that we don't have to worry about obtaining the extra parts needed. I.e., different mounts, adapters, hardware etc.
Old 11-21-2012, 07:51 PM
Wiki Edits: 15
I can see where you're going but in this case to me those seem like small inconveniences. There's really no replacement for displacement and when we're talking making a full size truck go fast, it's probably going to take deep wallets or more than 350 cubes.
Old 11-21-2012, 08:04 PM
I know why we did it to that truck back in the seventies, it was a no brainer. This truck pulled a 5 horse fifth-wheel trailer. They had a steep driveway that they literally couldn't drive out of with the trailer full, the 350 couldn't do it. They wanted a big block and the big blocks were BIG money. We bought the guaranteed Buick 455 with the TH400 for something like $500. If the 400 is owned already and in good running order it will pull circles around a small block.
The Following User Says Thank You to MARTINSR For This Useful Post:
Valkyrie5.7 (11-21-2012)
Old 11-21-2012, 08:32 PM
the 400 I have is in great condition and will be used for snowplowing and towing.
Also got a good deal on the moter. Anyone know the site to get the swap motor mounts?
Old 11-22-2012, 06:38 AM
LATECH's Avatar
Last journal entry: New Gas Tank
I have entertained thoughts of putting a pontiac motor in a chevy truck also.
Hey... they did it from the factory in 1958.
And , like was said, big power for plowing, pulling trailers etc.
I totally like the Idea, I will be watching this thread.
Fact is stranger than Fiction
Old 11-22-2012, 07:14 AM
Wiki Edits: 15
From the link against all odds posted:
"Speaking of mounts, I used the stock Chevy mounts with the Firebird's brackets. It fit like a glove."
Old 11-22-2012, 07:19 AM
LATECH's Avatar
Putting a 472 or 500 cad motor in it would also give good results, if you had one of course.
Having a K 10 or K 20 with big tires , like 44s and trying to drag it around with a whimpy SBC just dont get it. The torque of the pontiac or caddy motor would do very well.
The pontiac makes good sense. Lots of money is spent on stroking the 350 to a 3.75 inch stroke , for more torque of course. The pontiac is allready there. Even though the pontiac is more expensive to build...
I also think the firebird mounts would be the way to go, just be sure your block has the front pads for the mounts as the 3 pads to the rearward posisiton are for the A and B body cars.
Old 11-22-2012, 07:35 AM
Wiki Edits: 15
whoa.. let's not forget Olds and Buick either
Good tips btw, good to have some that knows Poncho motors helping out in the thread.
400 pontiac and 400 chevy?are they the same? 77'Omega Engine 34 07-01-2010 12:10 PM
400 pontiac and 400 chevy?are they the same? 77'Omega Engine 5 06-15-2010 05:51 PM
pontiac 400 or chevy 400 47chevrolet Engine 2 02-02-2007 02:08 PM
pontiac 301 to chevy 400 ????? hotrodkeith Engine 5 01-23-2006 06:03 PM
pontiac 400 to a 305 chevy BillyBob1950 Transmission - Rearend 4 11-22-2002 06:30 AM
