Does your heads have screw-in or press-in rocker studs? If they are pressed in, you might have one that has began to pull. If you have screw in studs, check for a worn cam lobe.
Studs are screw in and cam is new in engine. I haven't started the engine since new cam, lifters, poly locks and screw in rocker studs were installed. The heads had a valve job performed and it looked like the valve stems were ground even.
The screw in studs are all uniformly screwed down even with the head. No gaps or any thing like that I wonder if I have a defective stud? Maybe the fine threads on stud top are not cut to the same length as the other studs? Since I did set the valve in question to zero lash I am wondering if I should leave well enough alone. I had to cheater bar the poly lock nut 1/2 turn. BT |
You sure the center set screw wasn't screwed in further than the other polylocs were, causing it to bottom out? The threads munged on that stud or lock?
Nope, the first thing I did was back out the set screw so it was held in place by 1 rotation of threads. After I cheater barred the poly lock 1/2 turn I spun the set screw down and it locked in place.
I spun the engine over and watched the valve train and every thing moves as expected; no problems I could see. bt |
Prime with crank rotation by hand. The valves could have been adjusted wrong. Did you do it correct like this ? Not just turning to base circle.
Go in 90 degree turns , engine primed. At TDC position , Adjust intake valve on cyl , Adjust exhaust vlave. 1 , 2 , 8 8 , 1 , 4 4 , 8 , 3 3 , 4 , 6 6 , 3 , 5 5 , 6 , 7 7 , 5 , 2 2 , 7 , 1 Last edited by spinn; 09-18-2011 at 07:47 PM. |
Does the poly lock in question sit at the same height as the other poly locks?
Can you see the lifter? The lifter in question may have bled down and collapsed while you were trying to adjust it. |
| Valve lash | badknuckles | Hotrodding Basics | 16 | 05-31-2011 03:54 PM |
| valve lash??? | chevyelc81 | Engine | 5 | 03-29-2009 07:25 PM |
| SBC 350 Valve lash !¿?¿ | boneyard Buick | Engine | 5 | 11-09-2005 08:21 AM |
| If the valve lash is off.... | KeithB123 | Engine | 2 | 09-21-2003 06:30 PM |
| Valve lash | Sampson | Engine | 4 | 08-24-2003 07:27 PM |
