Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pontiac 400: Where Does Rubber Washer Go?
Old 10-26-2012, 04:36 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
The fairly thick rubber O Ring goes between the intake manifold to the timing cover. When you bolt them together they should line up perfectly, just pop it into the timing cover and bolt on the intake, when you torque it down it will make a tight seal.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
beertracker (10-26-2012)
