Pontiac 400: Where Does Rubber Washer Go? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2012, 03:38 PM
I wasn't paying attention when I removed the intake manifold from my Pontiac 400. The water pump & rear of the timing cover bolt to the front of the intake manifold. A rubber washer goes between these parts as a seal.
I can't tell from mine if the washer goes on the water pump or back of the timing cover? Does any one remember?
bt
Old 10-26-2012, 04:36 PM
Faith - Respect - Trust
The fairly thick rubber O Ring goes between the intake manifold to the timing cover. When you bolt them together they should line up perfectly, just pop it into the timing cover and bolt on the intake, when you torque it down it will make a tight seal.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
beertracker (10-26-2012)
Old 10-26-2012, 05:27 PM
WDCreech's Avatar
Grumpy Old Goat Herder
beertracker, put all of the intake bolts in, but ontly finger tight, then tighten the bolt between the timing cover and the manifold before you torque the manifold bolts.
Bill
The Following User Says Thank You to WDCreech For This Useful Post:
Old 10-26-2012, 09:33 PM
Makes sense. I don't pull manifolds very often and the old rubber O ring must have fallen out during manifold removal. I just needed to make sure I understand how the new one goes in before starting the job.
BT
Old 10-28-2012, 09:59 AM
To add to what Bill says, be sure to "chase" the threads (5/16-18) in the intake where the draw-bolt goes and blow the hole out with a good nozzle. Put a drop of oil on the threads of the bolt after you "wire wheel" it. Torque to 22 lbs. Torque the remaining bolts to 32 lbs., starting in the middle and "spiraling" your way out.
TIP: use a very thin film of RTV on the manifold-side of the o-ring to hold it in place while installing. DO NOT "load it up" with sealant.
Jim
Pontiac 400 vs. Pontiac 455 chevyelc81 Engine 7 03-19-2011 07:31 PM
400 pontiac and 400 chevy?are they the same? 77'Omega Engine 34 07-01-2010 12:10 PM
Olds 455 or pontiac 400/400 handymann3 Engine 48 02-03-2010 03:59 PM
water based washer solvent for parts washer 62CHEVYC10 Garage - Tools 31 02-03-2007 06:09 AM
1986 pontiac acaidian with a pontiac 400 mazmanian Engine 2 07-30-2005 01:35 PM
