400 wiring
There is only one wire from the H.E.I., unless you have a tach, that would have a wire from the H.E.I. to the Tach., I don't have a Gm. wiring diagram, in fact I have wired many cars, all street rods, but with an after market wiring board, And very few of them if any Use their board like Gm. Even though the are for a Gm. engine. There are so many different ways to get power, from A to B. But what I said is right If you do not have a Tach. then they are getting power for something else. the one wire goes from H.E.I. to Ing. switch. You said they are spliced together so I would Guess They are getting power for something else.
Later 35terraplane |
it looks like the green wire I have runs back to the tachometer. The tach has 3 other wires going to it, I dont know where they go. The 2 wires that are crimped together lead back to the little fuse box behind the brake pedal. I think those have to be where the yellow wire came from. I think one of the wires feeding the yellow wire is the purple wire that used to go to the coil. I dont know what the other blk/yel wire is from
The heavy yellow wire is the feed for the HEI in most cases
Artificial Intelligence is no match for Natural Stupidity Chet |
Pontiac 400 wireing
Column mounted ignition switches MAY identify connections by letter/number sequence rather than color. Again I know how to wire A lot of boards and using Gm colors But I don't wire by GM diagram. Also the black wire with yellow stripe GM in the older cars does not use one color wire with a stripe often I have seen that color on third brake lights from the brake light switch. the back of your TACH one wire to HEI, one to the fuse panel, one to the dash panel terminal on your light switch, and I'm not sure on forth, I need some help there. As far as which goes where not a glue. That's why it's a good idea to take some wire tags and write on them where each wire came off from GM didn't use a lot of colors, like someone said on the form they thought they had only four colors in mind. I don't know if this will help or not, you were asking a lot. we can go one step at a time, but you might have to call or go online with the name of your TACH to find out what goes where. If it is a VDO I have one in the shop I'm sure it will say, if not give us the name, if one of the guys has one he would be able to tell you. Check it out let us know. Later 35 terraplane Forth to ground on tach. Last edited by 35terraplane; 10-13-2010 at 05:44 PM. |
Oh yes, I know these wiring questions can be too broad and very hard to answer. But the explanation of what the 2 wires were that lead to the hei really helped, and I was able to figure it out. I crimped a new wire onto the 2 wires (purple and blk/ylw). I read a few diagrams, and it looked like there was one wire going from the fuse box (yes, I meant the fuse box in my earlier post) to the coil. I dont know why this purple wire is crimped with another wire, but I decided to let it be cause the car was like that before I got it, and i dont have time right now to fool around with it. i will do it later. ANyways, I got the new wire to replace the missing yellow, and hooked it all up. The engine fired right up! Now I got some miscellaneous stuff to attend to, the biggest being the god D@mn copper header gaskets....they leak like a pig....absolutely horrible...
pomtiac 400 wiring
Great glad I could help a little
| 400 sbc vs 400 pontiac | Artemis Entreri | Engine | 52 | 09-08-2010 06:17 PM |
| 400 Pontiac Valve Adjustment Question?? | budthespud | Engine | 11 | 04-13-2009 05:01 AM |
| Pontiac 400 wider than Chevy 350 | Goatman01 | Engine | 3 | 01-31-2007 12:11 PM |
| pontiac 400 | 409guy | Engine | 8 | 05-12-2004 01:57 AM |
| pontiac 400 question | 67bird | Engine | 3 | 12-04-2003 02:55 PM |
