pontiac 400 wont start - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2009, 06:58 PM
ok first things first i drove my car which is a 1970 pontiac catalina to the BBQ place. when i got back i changed the oil n now it wont start. i dont think it has anything 2 do with the oil change but i figured id tell you everything right before hand. ok so i replaced my distributor cap rotor button the ignition coil cleaned the carb. and nothing all it does is turn over sometimes it will start but runs like crap misses back fires iv checked the timing when i could get it running and its right were its soposed to be what could be wrong.
Old 07-20-2009, 08:57 PM
BackYardRacer
not a lot to go by but it sound like you have a few spark plugs wires out of place. did it act up at all on the drive there or home maybe timeing chain jumped
Old 07-20-2009, 09:02 PM
yea ran fine their and back. maybe it did ill have 2 check it tomorow being its my only form of trans portation i gotta figure this out. also though i might add sometimes before i could get in it it would run great and others i could get in it and it would seem like it was missing n wouldnt run well
Old 07-20-2009, 09:37 PM
BackYardRacer
have you checked that the choke is working properly maybe it sticks some times and fouls the plugs
Old 07-20-2009, 09:46 PM
just cleand the carb so it shouldnt now may have been a posibility. so you think change all 8 plugs and it may fire up
Old 07-21-2009, 12:56 PM
ok i fixed it! but being i dont know the name of the part i wont be able to give a good explanation on this. but ill try 2 explain what i did any way in case someone else has the same problem. what it was is i wasnt geting spark on all cylinders it turned out under the distributor cap on the distributor theirs a breakable ground which breaks and re contacts when spark is needed making a switched ground i guess is what it would be. well the contact plat was a lil wore and it was getting a constant ground. all i did was adjust the screw and it runs like a champ now
Old 07-22-2009, 01:09 AM
BackYardRacer
points i think is what your tring to say put a hei on that thing it would help a bit
400 sbc vs 400 pontiac Artemis Entreri Engine 52 09-08-2010 06:17 PM
How to make more power in a pontiac 400 psmvchaser Engine 15 05-17-2010 09:10 PM
Pontiac 400 wider than Chevy 350 Goatman01 Engine 3 01-31-2007 12:11 PM
57 Chev truck - 400 Pontiac motor jvo Hotrodding Basics 4 11-04-2006 10:32 AM
pontiac 400 low oil pressure, engine noise Blob Engine 3 08-12-2006 09:11 PM
