Pontiac 428
Any experiences with stroking a 428 with a 455 crankshaft? What's the gain in HP? What extra machining besides boring +30 or 40? Any specific Cam requirements for roller rockers, need to run roller cam for street/strip/cruise use?
Using a 455 crank in a 428 bored .030" IS a "455". Why?
What is the application? We have many running the 4" stroke with great results. The rod "angle" (rod/stroke ratio) is much better for higher revs. All factory 428 cranks are 'nodular' iron and can withstand over 700 HP. Same is true of the 455 cranks except the last version, which has no "N" on the cheek. The "103" (last three digits of the casting) cranks are nodular. Tell us more. Jim |
There are guys who would be glad to swap you a 55 crank for your 28... Not that it much matters but I like the 428. A lot. In the right application it'll run very good.
Thanks for the comments. I'm a bit confused as to why the 455 crank also. The pistons I have are for .30 over, the rods are stock 428. The idea to stroke the motor came from the previous owner. I do not "race" serious, just what to build a street screamer. Since I have a few parts, I just want to get the most out of the engine since I have options and the cost is better to spend it up-front and do it right so that I will have a bullet proof engine. I have a BOP rear seal to replace the rope seal. Are there any other aftermarket oil leak secrets? I've always had leaks from my Pontiac Engines. Another opinion question, The "Dual Grind" Comp cam "CL51-224-4" hydraulic, that's a 274/286 lift, 230/236 Duration and they only offer a 106" center line. Any opinions on this as a street cam with power brakes and vacuum advance dist. Thanks, Chet
Chet,
Changing the stroke increases the displacement. There's a solid foundation for the term "no replacement for displacement". However, the 428 is no "punk". Rick Holladay runs 10.30s over 130 with his in a '65 GTO convertible, over 3,400 lbs. and a 4-speed. It's a "pump gas" engine. Be absolutely certain to replace the connecting rods. A "stock" 428 rod is a casting, not a forging. It is also the SAME rod used in all other full-sized Pontiac V8s. It is the "weak link" in the chain. There are many good choices. The Eagle H-beam is considered the 'best for the money". For your application, though,.the RPM 5140 forgings are adequate. Most Pontiac vendors sell them, anywhere from $240 to $300 for a set. XE274H (the cam you mention) is a good "replacement" for the Ram Air IV cam in lower compression engines (under 9.5:1). The BOP seal is very good. We HAVE experienced ssues with "stock" blocks, though. The seal "groove" is not machined "close tolerance" because they knew a "rope" seal would be used. Sometimes, the Viton seal will leak because the groove isn't "round". We use the Best Gasket "GraphTite" seal. It's a graphite-impregnated rope. In aftermarket blocks, we use the BOP. BOP also sells a 1-piece oil pan gasket. More often than not, the rear seal gets blamed for a pan leak. The rear "lip" is problematic, and the new gasket "cures" it. Most important,. use no sealer between machined surfaces where a paper gasket is used. RTV causes more leaks than it fixes. If a little is "enough", a lot is NOT "better". Jim |
| Pontiac guy | pontiacsg | Introduce Yourself | 8 | 01-26-2009 08:34 PM |
| need 455 pontiac help | WDracing | Engine | 8 | 03-24-2006 01:59 PM |
| 1986 pontiac acaidian with a pontiac 400 | mazmanian | Engine | 2 | 07-30-2005 01:35 PM |
| pontiac 301 or 305?? | Trav | Engine | 1 | 11-16-2003 08:22 PM |
| pontiac 400 | hepcat | Engine | 2 | 09-18-2003 03:33 PM |
