pontiac 455 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2012, 08:08 AM
37 ford
pontiac 455
Is a pontiac 455 internally balanced or external ? putting in a 4 speed-posi
Old 03-09-2012, 08:19 AM
Yes.
Sorry, couldn' resist... All in fun.
The front "half" of the rotating mass is "internally balanced" (no changes outside the main bulkheads). There IS a slight imbalance in the rear, about 6"-oz. The flexplate has a series of holes all the way around. To one "side', there's an "extra" set of 4 holes, about 1" in diameter, not "reflected" on the opposite side. That's the "change" to bring it "in".
A balance shop can duplicate this imbalance on your flywheel without having to "rebalance" the engine. If a "stock" flywheel and unmodified, it's probably okay "as is", but I would have it checked to be certain.
This applies to all the later Pontiac V8s except the 265/301.
Jim
Old 03-09-2012, 07:22 PM
vncruiser's Avatar
Gearhead
What is a 4 speed posi?
428 Pontiac DENCOUCH Engine 14 02-18-2011 03:04 AM
Pontiac CPS help DoubleVision Engine 6 02-15-2011 06:20 PM
need help with my pontiac 301 backyardbuilder Engine 7 08-04-2009 06:58 PM
pontiac 389 or 400 Rufus_2 Engine 3 04-01-2006 04:39 AM
1986 pontiac acaidian with a pontiac 400 mazmanian Engine 2 07-30-2005 02:35 PM
