Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pontiac 455 high oil pressure
Old 03-11-2004, 02:03 PM
6567GTO's Avatar
6567GTO 6567GTO is offline
Tire Fryer
Red face
Well, I've got the same symptoms with my fresh 455 and have had to pull the motor each winter for the last 3 years to fix my leaky rear main. My dipstick blows out under full throttle too. This time I decided to send it to antoher machine shop for a tear down inspection and rebuild because I think my rings didn't seat thereby causing too much crank case pressure. I have a breather in each of my valve covers and a PCV valve in my valley pan which is then attached to my carb spacer plate. I should know by early next week if it's what I suspect. I'll keep you informed if you like.
I agree with Grusome that your oil pressure is good.
