Pontiac 455 and my starter will not disengage - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2012, 04:49 PM
i have a pontiac 455 and my starter will not disengage...any suggestions?
Old 11-25-2012, 05:06 PM
i NEED help!!!
You can loosen the bolts to free up the bendix. It is sticking. You also need to check the clearance between the starter gear and the ring gear of the flexplate.
Old 11-25-2012, 05:13 PM
i have already tried that. i have also tried shimming it every way possible, a new starter, new flywheel, and even replaced my main bearings thinking that my crank might have moved out of place just enough to hang it up but nothing has worked \m/
Old 11-25-2012, 05:21 PM
it hangs up on my flywheel the whole time even after i shut the engine off. it just constantly keeps grinding and i have to force it to go back into the starter. right now i have the engine sitting on a stand and i have ran out of ideas...
Old 11-25-2012, 05:39 PM
no it's just a normal starter nothing fancy or anything, but i don't the back brace for it. could that possibly be it? and i have gone up to five shims!! and thought that was way plenty considering if i went any higher my bolts would barely fit
Old 11-25-2012, 06:05 PM
yeah they're still in about half way and i thought 5 shims was too many. but guess i'll try more just to see what it does thank you!
Old 11-25-2012, 06:26 PM
gez! i just thought anymore then three would be to many since my bolts would barely tighten up
Starter wont disengage GUITAR1989 Engine 7 09-11-2011 09:32 PM
Starter wont disengage ericrcan Electrical 3 09-09-2010 09:28 PM
starter wont disengage jeff bonnell Electrical 19 11-25-2006 08:08 AM
Mini Starter won't disengage.. SOLVED.. Theresa Shank Engine 2 11-20-2006 08:30 AM
Starter wont disengage scott657 Electrical 8 10-16-2006 06:28 PM
