Pontiac 455 short block. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2010, 05:19 PM
Im going to pick up a pontiac 455 short block, the guy said he put new pistons and bearings in it....the way things go for me if i dont pull it apart something will break. Now if i take it apart, will i be hurting any of the bearings since they have already been torqued? Or can i tear it down and put it back with no worries?
Old 08-03-2010, 05:40 PM
bearings
There is no way a new bearing will be hurt by taking them out carefully. If they are new they will still be new.
If they are used, replace them, Pont are not the cheapest but still the rod bearings take most load.
With that said I have taken many engines apart that were assembled poorly.
New Pistons? only if you are going to bore it. Cylinder size and finnish is very important.
Moly rings are best if it has been freshly bored and honed for them, "smooth"
I could go on and on.
Chevy block interchangeable with Pontiac / Olds/ Buick JACK Engine 10 04-20-2011 07:16 PM
Need advise for trade. 408 short block for dart iron eagle block sherman8r Engine 6 12-06-2009 04:37 PM
Dart SHP Short Block Camaro2 Engine 2 11-13-2009 07:04 AM
455 Big Block Identification K5 Kustoms Engine 4 04-01-2006 10:38 PM
short block, long block astrops Engine 5 04-11-2004 08:14 PM
