-   -   pontiac 4x heads (http://www.hotrodders.com/forum/pontiac-4x-heads-227914.html)
blakethechop 01-03-2013 04:19 PM
pontiac 4x heads
hi i have a pontiac firebird 455 with 4x heads 113cfm i want to port heads and have read jim hands book has any body ported 4x heads and would you do chamber as in jims book or would this lower cr i want to keep heads and would appreciate info should i use higher cr pistons smaller head gasket mill heads ?any help would be great. i live in australia so locating different heads is a impossibillity and dont want to spend 3 grand on new heads shipped from usa
thanks blake
LATECH 01-03-2013 05:19 PM
113 CFM??? Do you mean 133 CC chambers?
What is your project goal? street car? strip?
I have to agree with Hcompton, having spent some change on head work.
WDCreech 01-03-2013 06:23 PM
Blake, Have those heads milled. For every .005" that they are milled, you will reduce the combustion chamber by about 1cc. I wouldn't go more than .060" and you'll need to have the intake side of the head milled an equal amount so that you won't have trouble putting any intake manifold on that engine.
Bill
blakethechop 01-03-2013 07:56 PM
thanks for replies the car is for street and i would like to port heads myself could anyone give me what they would do with the 4x heads what pistons what gaskets how much to mill of heads would they reshape combustion chamber changing heads is not an option i am going to put an xe 268 comp cam and a edelbrock rpm intake 750 carb .would love some ideas
cobalt327 01-03-2013 11:16 PM
If the heads are from a 455, the chambers are too big. If it was me, I'd find a set of smaller chamber heads like the well known 6X-4 or 4X heads from a 400. I used a set of these on a 455 in a '81 Camaro and was very satisfied w/the results.
I didn't go w/the 1.77" exhaust, either. Stock valve sizes. Much is made of using the bigger exhaust valve, and that's fine if the budget allows. But my way of looking at it is, every penny you spend on a set of iron production heads is a penny better spent on a set of aftermarket heads. Not saying you cannot get good results from iron heads- but keep the expensive mods out of the picture.
The best results are sometimes the cheapest: owner bowl work and porting, careful attention to quench, as well as other areas of the valve train.
Cleaning up the bowls by removing the lip just below the last angle of the valve seat (see image below) will help as much as anything. The valve guides have to be right before doing the valve job. The guides, valve job (three angle, but do not be tempted to change the intake seat from 30 to 45 degrees), and milling the heads to help compression are the only things I would recommend outsourcing. Everything else you can do yourself.
http://www.crankshaftcoalition.com/w...b/EXH_PORT.jpg
Choose a head gasket to raise after you've measured the piston deck height (as well as the actual combustion chamber volume) during the mock-up phase of the build.
Rods are bound to come up any time a performance Pontiac build is mentioned. If you have the budget, buy a set of forged rods for peace of mind if nothing else. But an iron head 455 is not going to make power past about 5200 unless you've done a lot of porting and have the cam to match. FWIW the stock cast iron rods are what I used- with ARP bolts and resizing- and they worked just fine. And according to Hand, he also thinks the cast iron rods are OK at that level.
From a recent post:
...(my 455/Camaro) was the tamest, easiest to drive anywhere, everyday, regular gas, 3.31 rear gear, 650 DP, all steel, full interior, 12 second vehicle you'd ever want to see.
I mean, how many cars w/those specs can stage in Drive, mat the gas from an idle and let the tranny shift out on its own (no governor work) and still run 12's on street tires? With a 10-bolt 3.08 run the same way (in Drive) it went 13 seconds flat in the quarter. Oh, and it had a 4777 Holley on a Performer intake (not the RPM, it hadn't come out yet). It was a ball.
The engine shifted out at about 4400 rpm by itself. For the best ET I shifted it at 5000 rpm.
Some Pontiac info:
Info/sites
Pontiac engine info
cobalt327 01-04-2013 10:53 AM
4X was used on 400 and 455 Pontiac engines. Fortunately, Pontiac engines are not overly sensitive to lower than "normal" compression ratio.
Pontiac production rods are mostly either just OK (cast iron, need ARP bolts) or real pos (forged production rods used in 1959-'62). There were decent factory Pontiac $uper Duty rods, but why even think about them when there's cheap aftermarket forged rods everywhere.
I'll reserve comment on "slapping cars together with left over parts", except to say GM might have lost their balls, but Pontiac didn't. Pontiac stuck to their guns longer than anyone else- they had a 455 Firebird as late as '76 IIRC. Yeah, it had low compression, but the raw material was there at least.
V8&4spd 01-04-2013 12:03 PM
Get a different set of heads. By the time you dump money into new pistons and all the machine work you would be further ahead with a different set of heads.
WDCreech 01-04-2013 03:45 PM
You don't read very well, do you? He had posted that changing heads was NOT an option!
V8&4spd 01-04-2013 03:50 PM
Oh well, changing the pistons, paying for machine work to mill the heads and special head gaskets is a option. There is more than one way to skin a cat. :thumbup:
V8&4spd 01-04-2013 04:30 PM
Stock a 455 with those 4X heads is only rated at 250hp. How much does the book say you will make with the recomended changes?
blakethechop 01-04-2013 04:41 PM
i hope to get 450 hp with head ported and milled new comp cam new edelbrock rpm intake 800cfm carb roller rockers.i have read that pontiac under rated the horsepower on the 455 during the fuel crisis is that true
cobalt327 01-05-2013 12:08 AM
The compression changes were made due to emissions standards being tightened. This meant no (or reduced) amounts of lead in the gasoline, which lowered the octane ratings, which led to lower compression. It had nada to do w/mileage.
Again- you need to CC the heads (both of them) first to try to determine if they've been milled before you got them. After that, mill the heads so the chambers are equal to one another (both heads match). When you're done, the compression ratio you will have depends on what heads you started out with and how much was milled. I don't cut them more than 0.050", personally.
If the heads have screw in studs, you may be in luck as far as the chamber size. Pressed studs are going to be the too-large 455 chambers. But screw in studs began to be used in more heads after mid '73, so that's not always going to help as an identifier. Pressed studs are a no-no, regardless.
Or just read up on them, instead of listening to me or anyone else: 4X Cylinder Heads - How to Pick the Right 4X Heads for your Pontiac - High Performance Pontiac Magazine
The factory ratings are not anything you need to concern yourself with IMO. Some were too high, some too low, some about right. But so what? What matters to YOU is how your engine is assembled, and it is not going to be the same as any factory engine anyway.;)
LATECH 01-05-2013 07:00 AM
I was thinking that a set of 4X heads off a 400, with the 98 CC chambers would work well. They still say 4X on them and would appear original. But it seems the OP probably wont go for that option. Cutting .060 of the heads he has would put them close to 100 CC which would also work.
A comp cams XE 262 would do pretty well in that combe with a tall gear and stock converter. An XE 268 would also work, just reduce the dynamic a Tad
Static CR would be 8.88 and Dynamic would be 7.53 with cam installed straight up. This is also without decking the block or milling the heads, using flat top pistons with 6 CC reliefs, .042 Head gasket
Not sure that would put it at 450 horses, but on a 455, with a Qjet, Headers and duals, recurved dizzy, I would think it would be close.Just sayin
vinniekq2 01-05-2013 08:10 AM
from what I have read about the heads,there is not enough flow to generate 450. I do see a large amount of torque and its not another sbc.Go for it.
cobalt327 01-05-2013 09:59 AM
Cutting the deck is all well and good, but you do not depend on cutting the deck for raising the compression as much as the deck is cut to obtain a good quench figure. That the compression may be raised is secondary to that. Get a clue.
Surely you must realize that the quench distance should be about 0.040". That is done regardless of compression ratio. The chamber volume and dish/dome volume is where the compression ratio is 'made'- NOT the head gasket thickness or deck height, except as a secondary effect to getting the quench right. Get a clue.
A Pontiac 455 can make well over 450 HP on 9.5:1 CR. 450 HP can be done w/9:1. This is NOT a SBC!!! Cutting a Pontiac head 0.060" most certainly WILL do something, AFA compression ratio is concerned. Get a clue.
One more time: The lower compression ratios of the '70s were NOT related to mileage- it was done for emissions. If mileage was a concern, they'd have used different cam timing and a different piston design. And higher compression can potentially get better mileage than lower.
Get a clue!!!
