Pontiac 6X-8 Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2010, 08:28 PM
Pontiac 6X-8 Heads
I have 6x-8 heads on my 400 now and am going go the smaller chambered 6x-4 head. Is there any reason to keep the -8 heads? Would they go good with a super charged 400?
BT
Old 06-05-2010, 08:44 PM
the 6x-4 is a smaller chambered head will rase your compression to 8.1:1 they origanially came on the pontiac350 91cc i belive some say 93.74 but i think thats a load of bull you will notice the diffrence and yes the-8 heads are low enought to run a supercharger but i dont know how much boost you would want to run probally want to run a -.005 dish piston if supercharging.
Old 06-05-2010, 09:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
My -4's were 95cc before any work, came on a 400.
A 0.005" dish won't affect the CR enough to matter.
As for what to do w/the -8's, I'd hang on to them; you never know what might come up- unless storage space is tight. YMMV. At least strip them down before you toss them.
They might be usable on a boosted 455 or stroker, but then you'd really want better flowing ports, and aftermarket would be the way to go.
Old 06-05-2010, 09:55 PM
As a side note my -4 heads were milled .040" so that should give a little extra CR & a three angle valve job. I guess I will keep the -8 heads in storage for now.
BT
Old 06-20-2010, 10:02 PM
Put them on a 455.
How good are pro comp cylinder heads automedics Hotrodding Basics 57 01-14-2016 03:19 PM
pontiac heads poman Engine 1 09-04-2009 03:04 PM
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 35 12-28-2006 11:11 AM
Pontiac 3.4v6 Cylinder heads ChevelleSS_LS6 Engine 3 06-22-2004 05:10 PM
Pontiac 400 heads Can Abyss Engine 3 09-23-2003 07:33 PM
