Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pontiac cam?
Thread: Pontiac cam?
Old 04-15-2006, 06:37 PM
cab cab is offline
Go to Performance Years
Wmarden - I hate to just send you to another board, but go to the tech forums (Street section) on . You'll find 4 billion posts about cams for Pontiacs...and everything else Pontiac related for that matter. Oddly enought, the Summit grinds 2800, 2801, and 2802 are highly recommended for the average street car. I hate recommending the 2800 because it is SOOOO mild, so my recommendation would be the 2801 - what exactly is your compression ratio with those heads? Comp, Crane, and Crower all make great grinds for that motor. Somthing in the 214 intake duration range will probably work well for you.
