pontiac in the chevy? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2007, 10:18 PM
65 c10, 283 tbi, 700r4, pb, ps
Has anyone put a pontiac engine, I beleave It's a 350 in to a 65 c10 chevy truck. what kind of motor mounts should i look for?
Old 12-06-2007, 10:38 PM
Wiki Edits: 31
Chevy did it from the Factory in the mid 50's w/ V8 trucks. they ran Pointac V8's b4 the SBC came out.
Old 12-07-2007, 06:15 AM
Will I ever get it done?
Last journal entry: Hood
There was a later model truck on eBay a while back with a Poncho 400 in it.
The motor mounts are about in the right place, they are just further back on the block. Since it is a 350, I don't think you are planning on racing it. I would make some 1/4" plates which would bolt to the block where the original mounts went and have holes for mounting sbc mounts forward. If you have access to a sbc, measure from the bell housing mount to the motor mount holes to get the correct locations.
Speaking of bell housing, the Poncho has a different pattern than Chevy. You will either need a bell housing for a stick car or a BOP automatic (you could use an adapter plate on the Chevy auto).
BTW, GMC used Pontiac engines after the sbc came out. 1955 -1958. The Pontiac V-8 and the Chevy V-8 came out the same year, 1955.
Old 12-07-2007, 08:45 AM
PRO 48 fleetline's Avatar
Last journal entry: Csr Electric Water pump
keep in mind starter is o different side aswell will need to extend your starter wire!
Old 12-07-2007, 12:58 PM
yes i planning on using a 700r4 that's in the truck, with adapter. I don't really understand what your talking about on the motor mounts, I guess when i start trying to put it in i'll find on. And yes gmc did have pontiac engines but i beleave the frames were wider on the 55-59 trucks than 64-66, so the mounts probably wouldn't work.
Old 12-07-2007, 05:33 PM
Wiki Edits: 31
I knew it was somthing like that.. do you know if the GMC 270/302 6cyl was the only engine GMC made for itself? I know GMC had the 305 V6 first, but Chevrolet adopted it.
Old 12-07-2007, 07:55 PM
The Pontiac-powered GMCs used the older mounting system with wide-based bellhousing mounts and a single front mount. Nothing you'd want to use in your conversion. I can send you pics of my '57/347 mounts if you need them.
Unless you have a 4x4, you might want to bypass the 700R4 & get a 200R4 because, being dual-pattern, it will bolt right up to your Tin Indian, and IMHO its a better trans.
Old 12-07-2007, 09:51 PM
The blocks are about the same width where the mounts go. The sbc mounts are further forward on the block than the location of the mounts on the Pontiac engine. You simply cut two flat plates, one for each side of the block. You drill holes to mount it to the block where the mounts would go and then you drill holes in the plates further forward to mount sbc motor mounts to the plates. Or you can move the frame mounts back until they line up with the Poncho motor mounts. Depending on the frame configuration, the plates on the sides of the block may be easier.
Old 12-07-2007, 09:55 PM
I am not sure if it was production or not, but they did make a V-12 which was two of the V-6 engines stuck together in a common block.
Sneaky Pete V12 hotrod
Old 12-07-2007, 10:32 PM
Here's the V-12 info:
http://www.6066gmcguy.org/Jolly-702v12.htm
If it was me, I'd get Pontiac motor mounts and the towers they sit on from a donor car. I'd bolt them all to the engine, set it in place, and adapt between your frame & the Pontiac towers in steel.
BTW, the left side exhaust manifold might be a little tricky to clear your steering, so have it in place when you determine your engine location.
Old 12-08-2007, 02:29 PM
ok i git what your saying now about the mounts redsdad thanks. I have i question on the engine, the oil filter sticks out sideways is this one of the crappy, pontiac 301?
Old 12-08-2007, 04:38 PM
WDCreech's Avatar
Grumpy Old Goat Herder
quote; "I have i question on the engine, the oil filter sticks out sideways is this one of the crappy, pontiac 301?"
Yep! You'ld be better off finding a 400. The 301 performance can be improved, but it's not worth it.
Old 12-08-2007, 09:07 PM
that sucks, atlest i didn't pull it out yet. guess it time to start looking for a diff engine again. ty for all the help
Old 12-09-2007, 11:31 PM
There's a couple of guys at www.67-72chevytrucks.com/vboard that have, or have had, Pontiac engines in trucks similar to yours. Might see if you can pry some info out of them if you can.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
chevy 350 or pontiac 400 or 455??? MIKE T Engine 17 02-04-2007 07:34 AM
Installing a chevy 350 in a pontiac 66pontiac Engine 14 11-23-2003 09:04 AM
pontiac 400 to a 305 chevy BillyBob1950 Transmission - Rearend 4 11-22-2002 06:30 AM
