is this Pontiac or Chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2009, 05:00 PM
GMR GMR is offline
I'm looking at a Jeep. The owner says the motor/trans is out of a '92 or '98 Pontiac. First off it has a quadrajet on it. I checked the usual Chevy area driver's side rear for a casting ID and found 14010207. This works out as a '80-'85 Chevy 350 truck, 4-bolt.
There is also a 207 stamped on each side of the block just above the pan. The distributor appears to go through the intake - I read that Pontiac 350 distributors did not do that. I asked him to remove the dist cap (HEI) but he didn't want to do that - I think Pontiac dist spin ccw instead of cw - so I couldn't check. There is no block pad on the passenger side below the head. Did '80 - '85 Chevy 350 have that pad?
What do you think?
Old 03-30-2009, 05:12 PM
ericnova72's Avatar
More for Less Racer
Casting # tells you enough, it's a Chevy.
Old 03-30-2009, 05:25 PM
amen. pontiacs were last made around 1980.
Old 03-30-2009, 05:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A Pont. has a separate timing chain case that bolts to the front of the engine. Bigger v-covers than SBC, a little smaller than a BBC, water x-over at the front of the intake is readily visible.
Dist. goes through intake, does rotate CCW. Heads have exhaust ports that point down at the ground, almost. Center pair of exh. ports have a head bolt running between them.
Old 03-30-2009, 07:16 PM
fast68's Avatar
likes chevy trucks & boobies
207 casting is 35o engine i have owned millions of these very common engine low power smogger crap
but can run good if in nice shape taken care of but that goes for any engine out there.
just google the casting number real easy.
http://www.google.com/search?hl=en&q...ngine&aq=f&oq=
mill the heads a little, put a better cam in, and good exhaust and a good intake ducting system and it iwll run really strong and efficiently
Old 03-30-2009, 07:59 PM
GMR GMR is offline
ok, thanks all.
Old 03-30-2009, 09:48 PM
WDCreech's Avatar
Grumpy Old Goat Herder
A Pontiac distributor is behind the intake. The Chevy distributor goes through the intake. Starter is on the drivers side on a Pontiac, and on the passenger side, on a Chevy. And as roknroy stated, the last factory Pontiac block, was in the early 80s, which was a short deck 301.
Old 03-31-2009, 03:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Of course it is. I'd claim a typo, fact is I wasn't paying attention. No more posting while CNN is on...
Old 03-31-2009, 06:28 AM
GMR GMR is offline
thanks for the update - nice car
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 05:46 AM
Need Help FAST!!!!!!!!!! millertime85 Engine 14 06-25-2008 07:01 PM
Will my Buick 350 (1970) fit into my 1984 Chevy K10? GFORCECONSTRUCTION Engine 0 05-22-2006 07:58 PM
Buick 350 or Chevy 350 72Skylark Engine 21 02-02-2006 02:10 PM
