pontiac engine in 66 impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2012, 09:33 AM
hi , does any know where i can buy engine supports and mounts for my 400 pontiac engine in my 1966 chevy impala ? any response will be appreciated , thanks
Old 08-02-2012, 01:51 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Try Performance Years, Year One, or Ames.
Old 08-02-2012, 04:41 PM
LATECH's Avatar
I have seen pedestals and mounts on E Bay from time to time. The B body setup is different from the A bodys so shop around.
Fact is stranger than Fiction
Old 08-02-2012, 04:55 PM
I believe you can pull the mounts from a Pontiac powered B body and use them as the chassis were all similar. Chassis from 1965 up into the what? 1980s? Can't remember when they changed again but late 60s to mid 70s for sure.
Old 08-02-2012, 08:44 PM
Onefunponcho's Avatar
Build it
I would just get some steel and fab them...
Old 08-02-2012, 09:04 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
60's b-bodys had a ton of sheet metal changes, and I'm not well versed enough to know if and where that relates to chassis changes. I imagine it's a lot like any other GM product and it's very much unchanged for a long period. That being said, I'd try 67 400 mounts for a Catalina. They're like $6 on rockauto.com
Old 08-03-2012, 08:31 AM
Ditto the Catalina. That's the "short wheelbase" version of the B-body, like Impala, Bonneville being longer. You will need the frame "pads" as well as the motor mounts themselves. '65-'70 should fit fine. Ames sells the pads for the A-body, but I don't know about the B.
Jim
77 impala engine decision help impala77boi Hotrodding Basics 3 04-15-2011 02:03 AM
62 Impala engine transplant itsandre Introduce Yourself 2 02-11-2011 05:04 PM
86 Corvette engine for my 59 Impala Bill Yarbrough Engine 2 07-23-2005 09:24 PM
Engine in my 1964 Impala roll 64 Body - Exterior 4 09-21-2003 10:03 PM
Engine in my 1964 Impala roll 64 Engine 1 09-21-2003 01:37 AM
