Pontiac engine pops - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2008, 02:18 PM
Mertz's Avatar
Pontiac engine pops
The engine is a 69 428 in my 66 Catalina convert. The engine starts fine with the choke wide open on the Qjet. It will continue to run until it gets warm with a few taps on the pedal. I have the points set to about 25 with factory calling for 30. I set them at 30 and it ran bad. I am getting some backfire "popping" through the exhaust. It is not regular but happpens often as it runs. It doesn't stop when the engine is warm. I have timing set to 12. The manual calls for 8 or 15 depending on the horsepower. I am not sure which I have so I set it for 12. It ran hot at 8. I also get a very occassional backfire through the carb but only when it is cold. Wires are relatively new and I have checked for cross fire.
Old 06-17-2008, 02:24 PM
Pontiac engine pops
points set at 30 , are you dwell checking or feeler guage them
30 on dwell and 19 on feeler guage
Old 06-17-2008, 06:33 PM
Mertz's Avatar
That's dwell.
engine swap 65 pontiac tempest airmech Engine 2 05-19-2008 03:12 PM
pontiac engine ID kelly4goons@hotmail. Engine 12 04-27-2008 07:37 PM
'54 Pontiac Engine Swap Monkey Hotrodding Basics 10 04-23-2007 11:29 AM
Pontiac 301 Engine Thuggishruggish3000 Hotrodding Basics 10 10-15-2006 10:15 AM
pontiac engine Id'ing 89silverado454 Engine 16 04-10-2006 07:02 PM
