Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pontiac engine question
Old 01-20-2013, 11:15 PM
cadillacdave1 cadillacdave1 is offline
The original factory motor 289 2v had 10.75:1 compression. Check what the stock cc of the heads were vs the cc of the heads you just put on. Then use a compression calculator, you can find online. I hope this helps.
