Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pontiac engine question
Old 01-21-2013, 12:58 AM
WDCreech's Avatar
WDCreech WDCreech is offline
Grumpy Old Goat Herder
Originally Posted by cadillacdave1 View Post
The original factory motor 289 2v had 10.75:1 compression. Check what the stock cc of the heads were vs the cc of the heads you just put on. Then use a compression calculator, you can find online. I hope this helps.
Pontiac never produced a 289, and you can't go by the factory advertised compression ratios.
