Pontiac engine question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2010, 02:32 PM
i just got a 72 pontiac lemans 350, if i put 326 heads on it would it work? and would it increase compresion? would i have to run high octaine fuel to run it? any feedback please....
Old 11-17-2010, 03:02 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
When Bill see's this he can help you out. (WDCreech) ponitac man knows his stuff. Or someone else might stroll by and know about this.
Cole
Old 11-17-2010, 04:25 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Changed the thread title, added Pontiac, making it more specific.
Old 11-17-2010, 04:44 PM
LATECH's Avatar
I have a 350 poncho that I have a set of closed chambered heads for. It runs pretty good now but I am considering doing something similsr to your Idea. I have some closed chambered heads (i havent CC ed them yet) that I was looking to run but they would put the compression ratio over 10.25 / 1.00 to much for pump gas. I am toying with having them cnc machined to a larger chamber size but with a specific shape in mind for flame propagation to increase burn speed with out having to much compression for pump gas. There is plenty of metal to remove for changing the shape to a heart or kidney shaped chamber and to also unshroud the valves wich I have heard is a problem with the 350 pontiac due to the bore size. ( Small). This creates a problem when going to larger valves as it makes the problem worse and then you have to chamfer the top of the cylinder to gain clearance. (Difficult and tedious)
With the 326 heads that would not pose a problem as the valves are smaller and would be less shrouded by the cylinder and the chamber.
Some port work may be beneficial . I would not do any to the ports them selves ( except for a deburr of the entry and runner) but would focus on opening up the "Bowl" behind the valve as to increase the airflow in that area.
That would probably gain more than bigger valves anyway, In my opinion.
One thing I have found also is pontiac exhaust ports are smaller than intake ports, at least more so than an average engine.Pontiac uses a dual pattern camshaft design ,the exhaust duration is longer than the intake duration. Check out camshafts for pontiacs, you will see, and that is why.
CNC machining can be pricey you can dump a buttload of cash in a set of heads, probably as much as a set of aluminum performance heads from what I hear, so spend some time thinking it over.You might want to read up on porting and C C ing chambers and such so you can do it yourself and save bucks. Maybe get a cracked head at a machine shop to practice on a little first and get a known race guy to critique it for you to get the Idea and a feel for whats happening.
By the way 65 heads and up will fit ,64 and back have a different bolt pattern for the intake,and I think that 72 and up may be different also. The difference in the 64 back is the bolt pattern, 72 and up is a different exhaust crossover and would be a big exhaust leak on a 71 and back head. I think that is an accurate quote.check that out also, it could be a problem for you as well.
Old 11-17-2010, 05:05 PM
WDCreech's Avatar
Grumpy Old Goat Herder
latech has it pretty well covered, but you didn't say which 326 heads you had or from what year 326. If they are '66 094 or '67 140s, you should be good to go. If you have '66 095 or '67 141s your compression will be to high for pump gas. Don't increase the valve lift to over about .450" because the notches in the pistons are slightly different than were the ones in '72.
Bill
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
engine swap question earthworm Engine 17 12-08-2003 01:53 PM
