pontiac gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2005, 11:56 AM
6969bird's Avatar
pontiac gears
I'm thinking about changing gears in my 1969 firebird, but i'm not sure what I can put into it. It is a 8.2" BOP rear end with either 2.56 or 2.73 gears in it, and i've heard you can't put anything numerically higher than 3.36 in those rear ends. I would like to put a set of 3.55 gears in so I can still drive on the freeway relatively easily.
-Is it true that nothing lower than 3.36 will fit?
-If that is true, why is that? Does the ring gear hit the carrier? Can I just clearance the carrier if that's the problem?
Old 06-05-2005, 11:08 PM
8.2" BOP - 2.76 & down / 2.94 to 3.23 / 3.31 & up
This is from www.oldsmobility.com
Pontiac 400 vs. Pontiac 455 chevyelc81 Engine 7 03-19-2011 07:31 PM
what's up with pontiac engines (or BOPs) bullheimer Engine 15 09-11-2009 09:57 PM
34 pontiac 81 camaro subframe install ? mobythevan Suspension - Brakes - Steering 7 05-19-2005 12:17 PM
how to change gears.... jackflash Transmission - Rearend 4 04-10-2003 03:47 PM
Pontiac xxx(madmax )xxx Engine 13 12-05-2002 07:03 PM
