Pontiac heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2010, 09:18 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Pontiac heads
Just looking at a 78 Trans am W72,WS6 option w/4 speed trans, They removed the B-W t-10 replaced it with a Doug Nash Race transmission, And to my question they upgraded the heads from the stock small valve heads with some casting #62 Big Valve so i am needing info on these are the good heads? He said it still has the original WC code Block in the car (WHAT IS A WC CODE BLOCK)just upgraded the heads has forged pistons don't know yet if it has been boared yet has true double roller timing chain and gears Harland Sharp roller rockers Hooker headers Flowmasters and 3.73 gears. Just need some opinions on this ride going to look at it today. and advice/ info would be great.
Cole
Old 03-28-2010, 10:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
#62 heads- 72-75cc chambers, 2.11/1.77 valves. Used on 400/428 around '68-'69.
WC is correct block for a F-body w/the '78 W-72 6.6L option. This engine came w/the 'good' 6X-4 heads, 2.11/1.66 valves, ~93cc chambers, hardened seats.
Old 03-28-2010, 06:09 PM
eloc431962's Avatar
Wiki Edits: 37
Thank's Cobalt, I did some research but wasen't sure what the factory heads would have been. he has the paper work on the car says it is the W-72 WS6 option. I got to measure the sway bar see how big it is also. Thanks again Cobalt.
Cole
Old 03-28-2010, 06:24 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Cole
You thinking on getting the whole car? It would make a nice ride...
Old 03-28-2010, 06:33 PM
eloc431962's Avatar
Wiki Edits: 37
Yea i think i will bring it home.
Cole
Old 03-29-2010, 12:41 AM
Bad Influence Racing's Avatar
Engine Builder/Head Porter
Those heads are actually very good d-port heads. The only issue you will see is the chamber size on the 400's, tend to see about 10.75 copression which will be rough on pump fuel. They were desireable back in the day for race engines and high performance street engines and work good. Did alot of engines with them. One of the things to do years ago with later year 400's with 6x or 4x heads was to just swap heads and alot of guys used these. They respond well to porting also. Hope this helps.
Kris
Old 03-29-2010, 08:18 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Delete. Double post.
WDCreech's Avatar
Cole
Did you pick up the car? Here's some info for picking pump gas friendly heads, that will give good performance. I like the 46s or 4C-5s for a street 400.
http://www.wallaceracing.com/headsearch.htm
Old 03-30-2010, 04:03 PM
eloc431962's Avatar
Wiki Edits: 37
Yep i brought it home and thanks for the link.
Cole
Old 03-30-2010, 09:30 PM
WDCreech's Avatar
You're welcome! I sent you a PM with a couple more links.
Old 04-01-2010, 01:38 PM
eloc431962's Avatar
Wiki Edits: 37
Here's a few pics of it after i cleaned it up detailed it , It was pretty dirty after the drive home and from sitting, It didn't have a pcv hooked up on it so i did that today i went to the driver side this time the passenger side valve cover was blocked off by a shied i guess, I'm just used to running them on the passenger side but guess it will be ok at-least it has one now.JMO
Well i tried to post some pics but i will have to re-size them but i did get them in my gallery if someone want's to check it out.
Cole
Old 04-01-2010, 02:48 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Cole, hope you don't mind, but I'm going to use some B/W for a couple shots- that's a SWEET ride!!
Are the door panels custom? I don't remember that style. A Doug Nash w/3.73's- whoot!
Old 04-01-2010, 03:41 PM
eloc431962's Avatar
Wiki Edits: 37
I don't mind at all Cobalt, You know i'm not sure about the door panels i will have to look into that, I know it has after market front seats and i really like them very comfortable they are scat seats. It pulls pretty hard with the Doug Nash and the 3.73 gears too i don't know how that trans is geared but i am going to try to find some numbers to find out.
Cole
Old 04-01-2010, 04:21 PM
SUX 2BU's Avatar
Very nice ride man Always loved them ever since I saw them almost new when I was old enough to notice cars (5 years old in 1980). Of course, the Smokey movies helped lol How much did you pay if I may ask?
Old 04-01-2010, 10:12 PM
Nice color ,I like the marty blue T/A's
455 pontiac heads. redskin58 Engine 1 12-19-2009 10:23 PM
pontiac 6x heads jake_arcticcat Engine 8 07-08-2008 10:58 PM
where is the best place two get performance heads for a pontiac 400 resonable 47chevrolet Engine 1 09-05-2007 12:14 PM
Pontiac heads richardbrian Engine 4 10-21-2003 10:44 PM
Pontiac 400 heads Can Abyss Engine 3 09-23-2003 06:33 PM
