Pontiac Heads! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2006, 01:23 PM
Pontiac Heads!
hey guys
i recently bought a 68 firebird, it has a 350 pontiac in it but i have a 400 ready to go into it. the problem is that i have some 5C heads. they are 400 heads but ive never seen them in performance applications. i usually see the 6x. does anyone have any experience with the 5C's or should i go and hunt down some 6X's?
Old 09-20-2006, 02:21 PM
nitro_baller4692's Avatar
floppers forever
here are some #'s to look at.if you are not going to go over .500'' lift on the cam 5c's are better,but if you are going to port the heads and go over .600'' lift find the 6x.
these #'s are in the right place.
imo
port volume, 5c 151cc int./138cc exh.
6x 158cc int./146cc exh.
valve sixes
5c int.2.110''/exh1,770'' bigger exhaust valves
6x int.2.110''/exh1.660''
flow#'s at .500''
5c int.222cfm/exh.171cfm
6x int.212cfm/exh.148cfm
Old 09-20-2006, 07:51 PM
pontiac cams
need specs on a cam marked cwc gmc uas on rear it has 960940 can ya help thanx
Old 09-21-2006, 02:22 PM
thanks, im planning to use a mild performance cam in the engine so i dont think ill go over .5 lift or will i? another thing i have found is contradictery info. that the 5C-9 heads in one place,(http://www.highperformancepontiac.co...d_performance/) they say that the 5C-9 heads are for a 350 w/A.I.R. and http://www.wallaceracing.com/head.htm is saying that the 5C-9 heads are for a 400 block. Do you guys know for sure wich engine my heads are for?
Old 09-21-2006, 04:47 PM
floppers forever
read this artical.
http://www.pontiacpower.org/ultimatehead.htm
Old 09-21-2006, 05:09 PM
i think im going to go play it safe and find some heads off of a 400 block, again the main reason is that i dont know if these heads are for a 350 or a 400, any ideas on how to figure it out?
Old 09-21-2006, 05:39 PM
floppers forever
5c heads were used on both 350 and 400's in the 70's.the 400 in 75 used 5c and 6s.the 350 in 75 use 5c but the 400 use either or.
olds #5 head johann Engine 1 07-30-2006 11:05 PM
What are the best heads to put on a 305? CCR Engine 6 11-06-2004 02:50 PM
292 Turbo Heads sb72elcamino350 Engine 1 08-16-2004 07:34 PM
Pontiac heads richardbrian Engine 4 10-21-2003 11:44 PM
Pontiac 400 heads Can Abyss Engine 3 09-23-2003 07:33 PM
