Which Pontiac HEI distributors will retrofit in a 1966 326? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2013, 05:33 PM
Old 10-12-2013, 05:55 PM
LATECH's Avatar
All of them/any of them. Clearance at the firewall is the most likely issue. It may need some tweeking
Also an HEI needs a circuit that doesn't have a resistor wire and it should be at least a 12 gauge feed wire.
Fact is stranger than Fiction
Old 10-12-2013, 06:09 PM
Banned
grab one of these and you will not have to mess with the firewall.
http://www.summitracing.com/parts/pnx-1281/overview/
Old 10-12-2013, 11:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
On the off chance you're using a Tri Power, the big cap HEI has clearance probs w/it. Don't neglect to set up whatever distributor you use w/a performance advance curve.
Old 10-17-2013, 09:19 AM
To be the "nay-sayer" here must point out, while Lynn is mostly correct, the HEI from the '81 models of 265 and 301 will NOT "work" as they have a computer interface the earlier versions don't have.
In the '66, firewall shouldn't be a problem, in either the A- or B-body. Heed cobalt327's statement about TrPower... Same is true of the old Edelbrock P4-B and it's "knock offs" (Weiand, Offy, etc., older dual planes). Performer and RPM have no clearance issues with HEI.
Jim
Old 10-17-2013, 04:48 PM
LATECH's Avatar
Hee Hee...I stand corrected. LOL
Actually I think they will fit, but as mentioned the CCC setup wont run, unless you perform the bypass on the computer circuit part of the module . And then it wont have any timing control due to the lack of a computer and sensors to accommodate any timing control.
Pretty much not useful for much...
Old 10-20-2013, 08:24 AM
Lynn,
All in fun, dude! Hope the folks reading this know you and I are friends! Note that I said "work", not "fit"... (:-
Jim
HEI dietributer on 1966 Pontiac LouieLewis Electrical 12 05-15-2012 06:36 PM
Small HEI distributors Sapper Electrical 1 11-07-2011 12:49 PM
Aftermarket HEI distributors heinj Electrical 3 03-27-2009 08:07 PM
HEI vs isolated coil distributors? sexypizzaman Engine 15 03-11-2009 09:41 PM
326 pontiac bullheimer Engine 6 06-28-2002 03:44 PM
