Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pontiac olds buick diference
Old 04-20-2004, 06:16 PM
Robinson Robin Robinson Robin is offline
Originally posted by polcat500
My engine is a 74 pontiac 350, and I thought I could use a olds 350 rebuild kit. I am guessing that only the cubic inches are the same?
An olds 350 pontiac 350 and buick 350 are as different as night and day. olds 350 rebuild kit would be useless for a pontiac 350 the only pieces you could use out of it would be the frost plugs. This concept alot of people find comfusing made worse buy the fact that in the late 70's gm started sharing the engines between divisions so for example you might buy a 79 pontiac t/a and have a olds 403 engine in it for example. Gm also made it confusing in that they had 4 engines with the 350ci displacement as well as 3 different 455's,400's and 3.8 v-6's.
