pontiac and poly lock prolems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2012, 06:23 PM
have 68 pontiac 400 useing comp cams ram air 4 cam wanting to use polylocks but they shoulder out on the factory 3/8 stud before they adjust up right, any advice would be deeply appreciated
Old 06-24-2012, 06:36 PM
LATECH's Avatar
Its quite recommended to have BBC 7/16 studs installed for polylocks.
3/8 bottleneck studs are not the best way to go .
Fact is stranger than Fiction
Old 06-24-2012, 07:11 PM
You can use the BBC rocker arm balls too if you are using stock Pontiac rockers.
Old 06-24-2012, 09:24 PM
pontiac rocker help
thx for the quick responce latech new to this site, really appreciate the help any machine work needed to put bbc studs in there
Old 06-25-2012, 08:18 AM
Pontiac rockers already HAVE a 7/16" "ball". BBC rocker parts do NOT "fit".
Agreed, use 7/16 studs. "Replacement" studs for BBC are the correct length.
Jim
Old 06-25-2012, 08:33 AM
Jim
For some reason they have always worked great for me. A set from Pioneer cost about $10 for a BBC. Maybe you're doing it wrong.
Old 06-25-2012, 08:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Guys are spot-on, the bottleneck studs gotta go. The Pontiac pivot balls are already 7/16", all the 7/16" stud does is eliminate the top 3/8" 'neck' part so the entire stud is 7/16", not just the 'bottle' part of the bottleneck stud.
ARP studs p/n 190-4003 w/hex nuts, p/n 190-4203 w/12-point nuts.
Old 06-25-2012, 12:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Probably a non-issue, but just the same- if you are using 1.65 ratio rockers, be sure to open the push rod holes in the heads as needed.
I've personally never compared the radii of the two pivot balls (Pontiac and BBC) to know if they're different of not. Always used Pontiac balls and rockers, as they come as a set.
Old 06-25-2012, 06:23 PM
reply to pontiac poly locky problem
thx to everyone for the great feedback and help with my problem awesome forum i am hooked
Old 06-26-2012, 08:50 AM
Okay, you "got"me. I've never actually tried to use a BBC rocker ball in a Pontiac rocker... The Pioneer part numbers are different, BTW, for Pontiac (RM-378, w/o "Ram Air", RM-384 "with") and BBC (RM-359). No, not "doing it wrong". Doing it "right" is replacing the entire rocker. If there's a problem with the "ball", the rocker isn't "far behind".
Kinda "moot" today, as only the restoration crowd sticks with stock rockers anymore, not unlike the Chevy and Ford crowds. "Good" rockers are readily available and similar in price to QUALITY small block stuff (cheezy imports don't "count"). Contrary to "popular belief", it isn't expensive to build a nice "street" Pontiac.
PAX
Jim
SBC Poly Lock Rocker Arm Nuts hoops Engine 9 06-13-2012 10:43 AM
Pontiac Poly Locks LATECH Engine 12 12-17-2010 06:45 PM
How to tighten a Poly Lock?? phatTweaker Engine 3 06-15-2010 10:03 PM
Thread-lock on poly-locks? MorrisonLC Engine 5 01-25-2009 10:31 AM
poly lock probs. barnym17 Engine 9 08-09-2005 02:28 PM
