Pontiac Power Steering problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2008, 01:30 PM
Last journal entry: Free tires
Any suggestions as to how to clear the head with a -06 line off the PS pump?
Used an inverted flare adapter and a -06 90, ground the header flange but it still hits. Straight or 45 was worse.
Old 07-21-2008, 01:46 PM
Earl's sells a low-profile 90 deg -6 hose end. P/N 609036. Have you checked out their website?
http://www.anplumbing.com/
Old 07-21-2008, 01:59 PM
Thanks for the link.
I called them, unfortunately they gave me bad news, really bad news and horrible news.
The low profile for that size is only 1/8" shorter.
The fittings and hose I have won't work on the pressure side anyway.
The right parts are expensive but don't solve the clearence issue.
I hate cars...
Old 07-21-2008, 02:07 PM
Is the problem that you're needing to go from the inverted flare on the pump to the AN -6 hose (which needs to be higher pressure capable, as you've found out). One option might be to ditch the adapter and form a short section of stainless hardline that has an inverted flare on one end to fit the pump and a 37 deg flare on the other end to go to an AN fitting.
Old 07-21-2008, 02:16 PM
I may have an old factory hose, it comes out with a sharp 90, not sure if I could cut it off at the rubber and have it flared with the -06 nut on it.
That kinda what you're suggesting?
Old 07-21-2008, 02:20 PM
Yes, but I assumed you'd want to use stainless for appearance.
Old 07-21-2008, 02:26 PM
Race car, appearance means little at the moment.
I might be able to take what I cobbled together to a local line shop and have something made. I'll try that tomorrow before ordering more expensive stuff I know nothing about.
If that doesn't work I'll try the modified factory line.
Question on 66 Mercury Comet steering and brake issues....... onebadmerc Suspension - Brakes - Steering 5 01-11-2007 05:41 PM
power steering won't return to center powerrodsmike Suspension - Brakes - Steering 32 10-12-2006 08:22 AM
Power Brakes for 52 chev car Looking for a steering box that will work Michael Bryan Suspension - Brakes - Steering 0 03-29-2004 07:22 PM
Power Steering and Power Brakes blindboarder711 Suspension - Brakes - Steering 1 02-09-2004 02:54 PM
Power Steering Problem 4X4Rodeo Engine 1 10-01-2003 07:06 PM
