Pontiac Powerglide shifter - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2008, 01:03 PM
67malibu's Avatar
I'm Still Alive and Well...
Ok...my project 67 Malibu w/ a powerglide is in need of a floor shifter...I've been hunting for shifters on ebay...I've been toying with the idea of a QuarterStick, or a factory shifter. The other day I found a LeMans powerglide shifter; at the same time found out it is a cable operated shifter...
...here is my question....will the pontiac shifter be a viable replacement for the chevrolet powerglide shifter? (providing of course the cable is available.)
Old 12-17-2008, 01:34 PM
With a couple of exceptions, Pontiac did not use the Powerglide, they used the Super Turbine 300. Completely different two speed trans. Having said that, the trans doesn't care what shifter is has, so long as the cable motion turns into the right rotational motion at the selector shaft on the trans. If necessary, you can modify the arm on the selector shaft to change the lever arm and thus tweak the rotational motion generated by this shifter.
Old 12-17-2008, 01:49 PM
SSedan64's Avatar
Should work fine.
400 sbc vs 400 pontiac Artemis Entreri Engine 52 09-08-2010 06:17 PM
ST-10 Hurst Shifter jamming Brimstone Transmission - Rearend 1 08-11-2008 03:47 PM
powerglide shifter old fords Transmission - Rearend 1 06-11-2008 02:13 PM
Using powerglide Column Shifter with TH350? Warrant Transmission - Rearend 1 05-15-2006 10:10 PM
Pontiac will drop GTO this year ckucia Hotrodders' Lounge 10 02-22-2006 09:44 PM
