Pontiac Press-In Oil Through Rocker Studs - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2010, 05:59 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
What years did Pontiac have pressed in, through the rocker stud oiling, and what diameter were they?...
Old 12-06-2010, 07:00 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Pontiac blocks were machined for stud oiling through 1964. IIRC, some H.O and SD engines used p-rod oiling in '63 and possible earlier. No factory stud oiling was used after '64, in any event. By '65 the blocks were made w/o stud oiling provisions.
The studs were 7/16 bottlenecked to 3/8" like the later studs, I believe.
Old 12-06-2010, 08:25 AM
345 desoto's Avatar
The reason I ask is because I have what is suppose to be a Factory "Super Duty" screw-in rocker stud conversion set. It has a drill bit, guide, 16 screw-in oiling studs etc....
Old 12-06-2010, 10:18 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Those parts may have been for the '60-up (until pushrod oiling became routine) SD engines, or for engines being modified to SD specs.
Vortec heads, SBC 350 and camshaft options RatPin Engine 15 03-18-2010 06:20 AM
Oil change nuisances Slipangle Hotrodders' Lounge 13 10-09-2009 03:32 AM
Smoke'n motor Red neck blazer Engine 25 06-09-2009 02:32 PM
pontiac rocker studs waynedawg Engine 1 12-27-2002 01:01 PM
