Pontiac rear end
I've been searching and searching with a lot of different answers. I have a 75 pontiac catalina 4 door and i am trying to get rid of these airplane gears in it. the diff cover has 10 bolts with the ) ( on the sides at 3 oclock and 9 oclock position. the ring gear and carrier have 12 bolts that are a left hand thread.I'm guessin a 7/16 bolt. the axles do have c clips and do not bolt on at the drum end like i keep reading. the best i can measure the ring outside diameter is right at 8.75" it is also a open rear with spider gears and all.. SOmeone please help me to identify what gears i need to order.thanks in advance.
Pontiac rear end?
nope. that cover is not scalloped on the sides like mine. mine also has a fill plug in the cover forgot to mention.
Sounds like that wierd Olds 10 bolt with a 12 bolt carrier, REALLY hard to find parts for from what I have seen.
Here's two sites that might help you out:
http://www.oldsmobility.com/10bolt-tech.htm http://www.richmondgear.com/01gm.html |
thanks for your help guys.but i have already checked those site and i can't find the right one.I keep readin about the p series for pontiac but that says it has bolt in axles and i have the c clips.i did email richmond maybe they can help me out too. i did write the numbers down off of the carrier and they are
2GM 8791 |
ya i found one of those too. lol!
| s-10 rear end | smallblocked_S-10 | Transmission - Rearend | 11 | 06-17-2005 05:43 PM |
| Chevy U-Joint doesn’t fit Pontiac rear end | 406chevelle | Transmission - Rearend | 6 | 07-05-2004 01:02 PM |
| Rear End Change | black66 | Transmission - Rearend | 4 | 01-28-2004 09:21 AM |
| Important rear end mounting question | 71gtx | Transmission - Rearend | 2 | 01-04-2004 06:05 PM |
| Ford 7.5" Rear End Traction-Loc Install | nightrain_rod | Transmission - Rearend | 2 | 12-30-2003 06:38 PM |
