Pontiac rear end swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2007, 06:25 PM
will the posi unit out of a early 80's 10 bolt out of a trans am fit into a 82 10 bolt in a Pontic wagon?
Old 03-11-2007, 03:39 AM
http://www.oldsmobility.com/10bolt-tech.htm has ID info for various GM rear ends. You're probably dealing with one of the 8.5" or 7.5" units. See which one(s) you have. If both are the same size, the posi unit will probably fit, but you have to make sure it's compatible with your gear ratio. Each design had two different carrier "series", depending on what gear ratio they were used with. Higher ratio gears tend to have the ring gear closer to the centerline of the pinion gear, and the ring gear flange position is how they differ.
63 Chevy2 rear end swap jokar1 Transmission - Rearend 1 01-26-2007 10:03 PM
Rear end swap question pearldrumbum Transmission - Rearend 1 05-21-2006 12:16 AM
1930 Model A Rear End Swap jnex Transmission - Rearend 4 04-16-2005 03:28 AM
Rear end identification help 71gtx Transmission - Rearend 1 11-07-2003 07:14 PM
