Pontiac T-350 and Chevy T-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2011, 10:23 PM
A person here in town has a TH350 for a 1983 trans am. From what I read there's alot of differences right? So it wouldn't be easy to bolt that sucker into my chevy pickup with a 454? My Pickup has a TH350 short shaft now. It looks to me like the bell housing bolts up different and the torque converter too.. Its cheap enough I thought I'd ask. I've mostly found people trying to stick a chevy th350 into thier pontiac..
Greg
Old 06-23-2011, 10:31 PM
BOBCRMAN@aol.com's Avatar
The big difference is the bellhousing. Adapters are readily available. Other than that, a 350 turbo is a 350 turbo. No matter what it came in.
Old 06-24-2011, 12:04 AM
WDCreech's Avatar
Grumpy Old Goat Herder
The '83 TA would have a Chevy engine. The Pontiac engine was dropped after '81.
Old 06-24-2011, 12:24 AM
tnsmith10's Avatar
when will it rain???
Greg
what engine did the trans am come with? and are you sure its a th350 in it? for the cars in that era, it more likely that the car came with a metric 200 or a 700r4. depending on engine. i have only seen a few th350's in the earlier camaros/firebirds of that era, but usually they were conversions from a 700r4.
also, if by chance it is a th350, and its factory, its more than likely to be a th350c, than a regular th350.
Old 06-24-2011, 01:08 AM
The trans am has a 305 in it. The TH350 was bought new (still in box) then they sold the car. So If its a 6" tailshaft I could use it?
Greg
Old 06-24-2011, 01:13 AM
SSedan64's Avatar
Yes, should fit if it's 6" Tail
Check for a electrical connector on the driver side = 350C
Old 06-24-2011, 01:47 AM
Thanks! It looks like my luck has turned for the better... Gotta love GM. I've got a ford pickup and it isn't near as easy to find parts.
Greg
Old 06-24-2011, 03:18 AM
SSedan64's Avatar
An easy way to tell the difference between a Chevy and BOPC/BuickOldsPontiacCaddy Trans is the top of the Bellhousing shape.
Chevy looks like this /\ or pointed in the center.
BOP looks like \___/ or valley.
Chevy Torque Converter uses Bolt & Nut mounting.
BOP Torque Converter uses Bolts only.
Unibell Housing has both patterns:
Old 06-27-2011, 12:52 AM
So the electric plugs are for the lockup. Could I make that work if needed? I see summit has SOME kits...
Greg
Old 06-27-2011, 03:57 AM
You need torque converter too,if it is 350C lockup
Old 06-27-2011, 08:03 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Greg
Yes, the lock up can be easily wired up to work w/a toggle, or a little more work to have it apply as per the OEM intended.
You need to know that the TH350C isn't a heavy duty tranny, per se. By that, I mean it was used behind a 305, and the 90 degree V6's, so it doesn't have as many clutches as can be fitted if mods are done to allow for the extra plates to be installed- a mod that I definitely would recommend you do for use w/a BBC, along w/the better intermediate $prag assembly- not just a hardened race.
See Post #11 for more on the TCC. Torque converters for the 350C can be found at Pats, TCI, and Keisler to name three, I'm sure there are others. But unless you modify the tranny to work w/o a lock up TC, you have to use a lock up TC.
Old 06-27-2011, 08:20 AM
55project's Avatar
Here's a link to ID auto tranny's>
http://www.crankshaftcoalition.com/w...identification
Old 06-27-2011, 12:13 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Greg
I would recommend using a kit with a brake activated disconnect. If you do not/forget to kill the power when stopping it will act like a manual trans and kill the engine.
Old 06-28-2011, 09:21 AM
55project's Avatar
Good info, i didn't know about this..
Old 06-28-2011, 09:51 AM
SSedan64's Avatar
Cars/Trucks that came with Cruise Control or Non-electronic OD Trans & TH350C have the correct 4-Pin Brake Light switch.
Run the 12V+ thru Brake switch, Toggle switch, then to Pin-A on 4-Pin connector to TCC Lockup on 2004R & 700R4. The TH350C uses a 1-wire connector.
When the Brake pedal is depressed it cuts 12V+ to Trans.
Chevy 350 in a 56 Pontiac NOM Engine 31 12-16-2015 04:59 PM
pontiac 350 and chevy 350 4x4Chevy Engine 5 02-21-2011 10:37 PM
is this Pontiac or Chevy 350 GMR Engine 8 03-31-2009 07:28 AM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 01:44 AM
Pontiac 350 in my 51 Chevy 51SportsCoupe Engine 6 05-14-2005 01:19 PM
