Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pontiac timing
Thread: Pontiac timing
Old 05-02-2012, 03:23 PM
GMCBEAST's Avatar
GMCBEAST GMCBEAST is offline
Is it possible when reinstalling, the plug wires were not installed right? As mentioned before Pontiac's timing is counter clockwise. Firing order is the same as Chevy I believe which is 18436572, with #1 being (while facing motor) on front right with 3,5,7 behind it and #2 on left with 4,6,8 behind it. Distributor sits on opposite side of cam gear than Chevy so it spins counter clockwise. Just something you can check out, hope it helps.
