pontiac YA 455, coded for 1970 GTO, loading up - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2007, 08:22 PM
Gladis's Avatar
Withdrew the money today in cash to buy a 70 firebird with a 70 GTO motor in it. I believe it is a 70 gto motor by the numbers, there is no such thing for any year as a YH 455, correct? I think he misread the serial on the block. Anyway, he says the engine is loading up when it gets warm. Basically he says it feels like it's burning real rich at lower throttle, really groggy, then at higher throttle it comes out it's slump and goes. By anyone's estimation is this a carb issue? I am going to double tap the timing on arrival with the timing gun, he doesn't know what it is adjusted to, or even what it should be. For a Pontiac 455, putting out stock 360 hp, what size and model of carb should be put on it. Also, how do I tell the difference between a 600ish and 700ish holley carburetor( that is the current carb setup, intake is not an edelbrock, but is aftermarket. He also said that the issue may be caused by the intake, I think he is referring to the seal may not be sealing, a vacuum leak maybe? I also have another general question, a pontiac 455 is a 400 with a different crank and stuff, but still the same base block and dimensions right? Thank for your time and expertise.
Old 04-07-2007, 06:03 AM
pont
unless the bird is very well worth the money be carefull where you tread,,make sure you are getting what you think...doc41
Old 04-07-2007, 06:08 AM
Pontiac
The numbers that I find to fit a 1970 455 engine block are 231386, and 487638. That would be the number on the drivers side at the back of the block. Sometimes tough to read while still in the car. In the Motor repair manual I have it does list a YH code for a 455 w/auto trans. and a 4 barrel carb though. 1970
It shows timing to be at 9 degrees initial, at 650 in drive. These numbers are totally stock.
On the carb issue, read the numbers that are stamped on the choke tower, then go to a Holley web site to identify.
I would say 750 cfm minimum for the Holley. Some of the Pontiac guru's might have a different opinion though. I've run an 850 for years on an old Edelbrock Torker, and had excellent results. My 65 GTO is race only however.
Sounds like the carb may need a rebuild, or adjusted. Put a vacuum gauge on it and see where you're at on vacuum. Tune for optimum vacuum.
Old 04-07-2007, 11:52 AM
Gladis's Avatar
1970 455
http://www.gtoalley.com/engcodens.html
I'm Bored...How About A 1967 Pontiac GTO Project ??? izzymiddleton Hotrodders' Lounge 9 03-07-2009 10:26 PM
Pontiac 455 Head Question BattlestarOne Engine 15 01-29-2009 09:22 PM
gm th400 4 bolt- to- 455 pontiac.... how do i make it fit... 71_gto Transmission - Rearend 11 04-04-2008 06:18 AM
Pontiac GTO commercial street racing fourbyfourblazer Hotrodders' Lounge 28 08-11-2005 04:15 AM
Torque specs for a 75 455 pontiac flywheel 64_catalina Engine 2 06-28-2005 10:50 PM
