10 isn't bad for a hotrod.
Get an overdrive or change cams. Troy |
It only gets 10 on the hw...not throught stoplights. We looked at the overdrive, but thats more than a new transmission. And for the cam.....we prolly will change it if we ever rebuild the engine.
If it's a 1/2 ton you should be getting better than 10..............3/4 or 1 ton, I could see 10.
Do a tune up, check to see that the choke is opening all the way.............could be a number of things. The fact that it wouldn't idle tells a lot...............
Ontario Rodders |
Don't add overdrive, replace the transmission with an overdrive transmission.
10 is not bad for a hotrod. If it has a big cam there is no telling what kind of compression or carb. and jets it has. Troy |
poncho, it wouldnt idle with the stock stall converter because of the cam. its a 1/2ton
We really dont know much about the engine....it doesnt run very good. We dynoed it and it made 240hp and 260ftlbs@RW. not very impressive at all.... It was very rich so we put new jets and rods in the carb(which is too big, 750). I think that made a difference...but not much. |
Even with a fairly radical profile cam, it should still idle.
Ontario Rodders |
OK...that and the hi stall converter (slippage) are probably the reason for the bad mileage.
Ontario Rodders |
Sure...if you want to spend the money. Why not go with a more streetable cam, converter....................you will be further ahead for less money.
If you are not worried about the money, don't worry about mileage.
Ontario Rodders |
Well short of changing the internals it seems the only big increase you'll see is going to be from an overdrive, and/or a MPFI system. Both of which are going to run you 1000+ bucks. You have your answers, its up to you to decide what to do with them.
Bringing history and technology together. |
Here's what I'd do...
1. park the truck and drive a boring economical car as a daily driver 2. save money 3. get OD tranny, 600 CFM carb, more streetable converter, and a cam designed for torque (a fairly mild cam); the 327 if I'm right is more of a midrange-hi rpm performer. Then, it should get better mpg. 750cfm is wayyy too big for a 327 unless that thing was built to kill. |
