Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Poor performance, gas smell, black smoke...
  #41 (permalink)
Old 08-15-2009, 04:27 PM
carsavvycook's Avatar
carsavvycook carsavvycook is offline
My 2 cents worth
Wiki Edits: 3
Originally Posted by jgs240
I have already begun tearing it down. I removed the carb, removed the float bowls and started on removing the gaskets (they are oooooooolllllllddddddd). I stopped for today so i can go to town, clean up and start fresh tomorrow after doing as much research as possible tonight on how to rebuild this.
1) There is a nickel colored plate of metal that was inside one of the float bowls. It has a very odd fastener head (in-law called it a "figure 8" fastener). What is this called? And what is behind it? Anything that i shouldn't be messing with?
2) Anyone see a good link/writeup on rebuilding these? I see borders has a Holley Model XXXX rebuild manual, but id rather not make the 40 minute drive tonight to get that. Or any tips for me? Anything helps when its your first time
Can you post a pic of this?
Be sure to keep the old gaskets to match up with the new ones in the kit.
