Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Poor performance, gas smell, black smoke...
  #45 (permalink)
Old 08-15-2009, 06:19 PM
carsavvycook's Avatar
carsavvycook carsavvycook is offline
My 2 cents worth
Wiki Edits: 3
Originally Posted by jgs240
Ill try to do this from here out. The gaskets holding the float bowls on are beyond toast. They bowls must have been pretty dry for awhile, because these gaskets are not coming off easily.
Is their a trick to getting these off more easily?
Spray them with a little carb spray, and while they are still wet, they come off real easy.
The gaskets I was referring to are the metering plate to the body gaskets. You will need to match up the holes, and slots.
