saitek5678
isn't turning the screw out losening it? Whatever, I need more frogs in my life
thanks cook, im looking into it now.
Also i just went out and found two loose plug wire boots, they clicked when i pushed them down. Its smoothed out a lot, but i am still getting noticeable black smoke. Which way should i be turning the float screws/nuts? 3 1/2 threads showing right? |
Followed your directions to a T, but there was no difference. For reference, they were around 2.5-2.75 threads before i adjusted it.
Should i leave them where they were, or leave them where you instructed me? |
saitek5678
If you do not find anything wrong, you may have a sunk float. This would require the removal of the float bowl in question. Did you test drive it? |
No we did not test drive it, i thought that if goosing the throttle did not result in what we wanted then its not fixed....is this wrong? |
Bingo
Even though i didnt follow your directions exactly the first time around, i lucked out and found this when i pulled the needles: ![]() Both have severe o-rings deterioration and both had little bits clogging the seats. But now my question is this....if this is how these look...what else should i be concerned with? |
saitek5678
I would get a rebuild kit and rebuild it , ive done very many, its easy, just follow the intsructions with the kit, questions, come here!
At this point, I would pull the bowls, and metering plates off and blow out the jets, and passages.
Those o'rings were flooding your float bowls, and it does sound like your jet's are flowing good, as it is running very rich, though. You might just get lucky, like finding a 'heads up penny', or a '4 leaf clover', and just need a quick o'ring change. I would also suspect the power valve diaphragm being ruptured also. |
saitek5678
any Call the nearest parts place, Napa, checker, whatever , You will need the numbers off the carb though, they will be stamped somewhere
| HI!!!! smell that smoke? | kik_start | Introduce Yourself | 2 | 12-02-2008 08:01 PM |
| strong exhaust smell and smoke after idling??? | 69elcaminoss | Engine | 6 | 04-08-2004 03:12 PM |
| black Smoke and Stalling | jrm123180 | Engine | 11 | 03-09-2004 11:41 PM |
| Motel 6: Would you like your room to smell like smoke, or just cat pee? | bullheimer | Hotrodders' Lounge | 8 | 01-02-2004 05:11 PM |
| Black Engine Smoke when put to the Floor | 91formula | Engine | 12 | 03-18-2003 08:01 PM |
