Poor performance, gas smell, black smoke... - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 08-16-2009, 05:45 PM
Thanks again!
I will make one more attempt at this today, my wife gets out of work in 45 minutes and i have to pick her up.
Could you by chance, tell me what the assembly with the red/pink spring is/does? It is considerably looser (more play) than before i took the carb off and replaced the float bowl gaskets today. Its in the last pic.
  #62 (permalink)
Old 08-16-2009, 05:56 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
That is the accelerator pump adjuster. In that picture it looks like it is a little tight. This will be pumping fuel in too fast.
In your earlier pictures, you could see a few threads showing on the top of it. Now it looks like the nut is even with the top of the threads.
Keep in mind, making any adjustments to the idle speed screw, changes this adjustment.
  #63 (permalink)
Old 08-16-2009, 05:57 PM
ericnova72's Avatar
More for Less Racer
Spring is accelerator pump override spring. It should be adjusted so that there is no slop between its head (plus 1/4 turn preload )and the pump lever it pushes against. You did put the spring(different spring) back inside the pump diaphram housing, correct??
  #64 (permalink)
Old 08-16-2009, 06:01 PM
I got as far as 2.5 turns out on each one, but it never fired. I am beginning to get a gas smell as well, flooded maybe?
The throttle plate looks like it has about 1/8" opening, but its hard to say. I am judging that based on the angel of the butterfly's, i cant actually see below the throttle plate.
I will adjust the accel pump to match what you are describing if i get time tonight/the next day i get time.
Anything i should be thinking about while i have some down time?
I just realized that i forgot to check the fuel levels in the bowls...something else to look at.
  #65 (permalink)
Old 08-16-2009, 06:03 PM
I didnt pull the housing apart, i was a little leary looking at the diagram. Sounds like maybe i am due to pull the carb again, and try and do a full rebuild this time instead of just the fuel valves/float bowl gaskets?
  #66 (permalink)
Old 08-16-2009, 06:12 PM
My 2 cents worth
Wiki Edits: 3
Did you install the new power valve from your kit?
  #67 (permalink)
Old 08-16-2009, 07:11 PM
No i did not, another cause of this?
  #68 (permalink)
Old 08-16-2009, 07:14 PM
I was just going back and looking at the carb before i removed it and noticed i hooked up the linkage differently. So yet another thing that could be causing problems.
This is the before:
This is the after:
  #69 (permalink)
Old 08-16-2009, 07:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by jgs240
I did set the fuel valves like cook explained in this thread @ 3.5 threads out.
Anyone have a next step for me?
Set the float level by removing the sight plugs (one at a time) and adjust the float level to where there is just a trickle of fuel coming from the open hole at idle.
A bench adjustment should have been made w/the floats assembled into the float bowl, the float bowl is then carefully inverted and the float level is adjusted by setting the float to be parallel w/the bottom (what is now the bottom, w/the float bowl inverted) of the float bowl.
More from Holley HERE.
And a decent page on the Holley, w/details and adjustments HERE.
  #70 (permalink)
Old 08-16-2009, 07:38 PM
My 2 cents worth
Wiki Edits: 3
Yes, One 'fart' or 'backfire' back through the carb, can cause it's diagram to rupture. This will really make them run rich. They do make a kit you can buy, that will solve this problem on the older Holley carbs. It consists of a drill, a tap, and a plug with instructions.
Switching your linkage back to the correct hole will help. LOL I have done this same thing myself.
  #71 (permalink)
Old 08-16-2009, 08:36 PM
Thanks cobalt, ill be reading plenty tonight.
  #72 (permalink)
Old 08-16-2009, 08:37 PM
I had a pretty decent backfire two days ago while i was trying to start it just before i took the carb off...but then again it was running pretty bad before that as well.
Either way, it looks like i will be getting pretty familiar with this carb
HI!!!! smell that smoke? kik_start Introduce Yourself 2 12-02-2008 09:01 PM
strong exhaust smell and smoke after idling??? 69elcaminoss Engine 6 04-08-2004 04:12 PM
black Smoke and Stalling jrm123180 Engine 11 03-10-2004 12:41 AM
Motel 6: Would you like your room to smell like smoke, or just cat pee? bullheimer Hotrodders' Lounge 8 01-02-2004 06:11 PM
Black Engine Smoke when put to the Floor 91formula Engine 12 03-18-2003 09:01 PM
