pop noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2007, 06:54 AM
pop noise
I have a popping noise from the rear. It is not all the time is more in reverse and during initial acceleration. Wheel bearing, u-joint(new) or rearend?
Old 10-07-2007, 06:56 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Sounds like a u-joint. Have you checked them?
Old 10-07-2007, 06:59 AM
what to look for
The one in the back is almost new. The one in front is old. How would I check them, what to look for?
Old 10-07-2007, 07:04 AM
Lost in the 60's
Wiki Edits: 4
Grab the drive shaft behind the joint pull and push up and down....turn shaft a quarter turn and do it again......see if you can see or feel slack.
Old 10-07-2007, 07:06 AM
Lost in the 60's
Wiki Edits: 4
If your new one was put in improperly...bearings not feathered etc. it could have already failed on you. Check both joints real good.
Old 10-07-2007, 07:16 AM
ok
ok will do. I thought that is how I would check but was not sure.
350 pop noise (new cam, heads, ect) David03 Engine 40 12-22-2005 03:39 PM
Overefficient cooling system and popping noise. TVR383 Engine 8 11-09-2005 08:17 PM
Pop pop pop pmeisel Engine 23 03-06-2005 07:00 PM
LOUD POP! noise when turning right in S-10 cknox88 Suspension - Brakes - Steering 3 01-12-2005 07:31 PM
valvetrain gurus: need help identifying mysterious valve noise blndweasel Engine 10 03-04-2003 07:59 PM
