Pop Quiz - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2002, 07:53 AM
Mertz's Avatar
Post Pop Quiz
I think I already know the answer but here goes.
I pulled some plugs out of the 350 last night to see how it was running. (I just drove it 25 miles with water injection, since removed) The first one looked great, a little yellow on the end of the insulator and a clean tip. I pulled another one at random and it was pure white with just a little carbon on the metal base. It looked like it has never fired. I had just enough time to check to see it I was getting power to the plug and it was fine. I checked other plugs and they had the same yellow color.
I tried running it with the plug wire off and it ran the same as with it on. I heard a little tapping noise from that side.
A couple of days before I put the vacuum gauge on it to try to vacuum time it and there was a steady reading of 14. I had the valve cover off to install a pcv valve and noticed that the rocker arms are loose but there was no tappet noise. There is no water or gas in the oil. The engine obviously idles rough. The plugs were all new Autolite 26 with new cap and rotor and wires.
Any opinions?
Old 08-21-2002, 11:36 AM
aka Duke of URL
Question
[quote]I pulled another one at random and it was pure white with just a little carbon on the metal base. It looked like it has never fired. I had just enough time to check to see it I was getting power to the plug and it was fine. I checked other plugs and they had the same yellow color.
I tried running it with the plug wire off and it ran the same as with it on. I heard a little tapping noise from that side.<hr></blockquote>
Had that plug been firing, you would have noticed an RPM decrease. It is obvious that the plug is not firing in that cylinder. As for the noise, it may be an internal defect. The way to check for a bad cylinder (piston slap-cracked rings-piston pin) is to take the power off that cylinder and listen.
Was every rocker arm loose or just a few?
[ August 21, 2002: Message edited by: KULTULZ ]</p>
Old 08-21-2002, 11:42 AM
bullheimer's Avatar
NEVER use credit cards!
Post
cant really tell from what you have here -how are your wires? rockers can feel really loose and still have no play so be okay. if you start it and can find the one thats tapping tighten it till it stops then give it another half turn-didn't i just tell somebody else this this morning?
Old 08-21-2002, 03:27 PM
4 Jaw Chuck's Avatar
Post
Just because the plug just came out of a box does not mean it is any good, I would switch some plugs around and see if it does the same on the other cylinders, better yet throw one of your old plugs in that is known good and try it. Next I would check the compression and see what it is.
— Han Solo
Old 08-21-2002, 03:48 PM
Mertz's Avatar
Post
My guess is that it is a bad plug. I thought maybe it was a stuck valve but I get a steady reading on the vacuum gauge. I am going to buy a new plug and install it tonight. I will let you know tomorrow who got the right answer to the quiz.
I am also going to pull the plug and see if I get air coming out of the hole. This to me would tell me that the valves are closing. If nothing or its weak I'll pull the valve cover and watch the valves.
The rockers can wiggles but I think they are tight to the push rods. It seems like to many of them were loose at the same time that is what got me thinking about stuck valves.
If it is the plug it the first time I have ever had a bad Autolite plug in my 20 years of using them.
BTW there was absolutely no change in engine speed or idle smoothness with the wire disconnceted. Again bad plug.
Old 08-22-2002, 07:42 AM
Mertz's Avatar
Thumbs down
There is no winner, including me.
Put in a new plug and did not notice any change in idle with or without the wire connected. Was really hoping everything would smooth out. Checked the old plug and it was firing. (Guess the Autolites are still OK).
Checked the compression and got a 115 in that cylinder, #6. I checked #1 and got 130 but the engine was a little warmer. Not good but not bad.
I pulled the rocker cover and the rockers can slide sideways but seem to be tight on the pushrods. This is an Olds 350. It has little plastic plugs on the rockers. What are these for? How do you adjust the valves? There are no screws on the rockers. I couldn't adjust them if I wanted to. I started the engine with the cover off and the valves are working just fine.
I put everything back together. I fine tuned the idle screws and got my vacuum up from 14 to 18. I timed it by ear and had the vacuum at 18. I tried timing for max vacuum and backing it off 1", took it for a test drive and got a lot of knock and ping. Kept backing it off until I had no more ping. Set if for best performance. Went back and reset it by ear, test drive, and it ran better. Didn't check it with the timing light.
I plan on running it for awhile and rechecking the plug. You don't suppose the water injection cleaned all the deposits off the plug do you? JUST KIDDING 4 JAW!!!!!!!.
I still don't like the way it idles. The vacuum is fairly steady with only less than 1/2" change but it still seems to run with a miss. I have a 40 Packard and I can put a quarter on edge when it idles and it won't fall. I like my engines to purr. Even my 428 has been tuned to run reall smooth at idle. Is this just inherent in the 350?
I pulled the wire off the #1 plug and didn't really notice any change. I did hear the slight ticking sound that came from #6 when the wire was disconnected. It must have something to do with no explosion in the cylinder and you can hear the valves.
Long and short of it is that the tuning helped. I still think it should idle smoother. And I am not sure why that plug was so clean.
Old 08-27-2002, 11:13 AM
Post
What is the condition of that plug wire? Do a resitance check on that wire and compare it to the suspect one. Or just switch wires and try your on/off test on that cylinder. You are assuming mechanical, but it may be ignition. Good luck.
Walt in SoFlo
Old 08-27-2002, 12:45 PM
Mertz's Avatar
Post
I checked the wire by using a plug and grounding it and it got spark to the plug. They are all new wires (doesn't always mean much). I still think it might be an ignition problem but what?
I am going to check some of the other back plugs and see how clean they are. You never know it might be the water. The plug in question however doesn't even show signs of getting hot on the outside of the plug.
