Pop Rivets for patch panels - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-31-2012, 04:04 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
Originally Posted by 66GMC View Post
Sorry, I disagree ... on both counts ... unless "a few" means all the fingers on both hands
1.) To buy a "hobby" 140A GAS mig welder at Canadian Tire is at least $500.00.
Buying a used flux-core (gasless) wire-feed welder would be a mistake, too. You can't do a decent job on sheet metal with one of those.
2.) I can't see a darn thing wrong with using the correct type of panel adhesive on sheet-metal *provided* that its not a structural body component(i.e. rocker panel) That Norton Speedgrip stuff can be sanded, primed and painted ... and I've never heard of any "shrinkage" problems with it either. Around a door handle? Well maybe ... that repeated flexing *might* cause seperation, but I sincerely doubt it.
This notion of "a patch panel blowing off your car at highway speeds" is pure nonsense, IMO, unless you're using Elmer's white glue or sumpthin'
This article dicusses some of testing that has been done: Putting the Metal to the Metal
If anyone has any info to the contrary, please post it to this thread for discussion.
I have no worries about it "blowing off" or not being strong enough. Did you look at the OP's pics?
He mentions making the panels himself. I'm pretty sure that they are not going to fit so perfect that they won't need major planishing and adjustments with a hammer and dolly. I just can't see doing that after the glue has set.
As for the welder, I bought one about 10 years ago at CT for 300 bucks. If they're 500 bucks now CT is doing OK as the price of the cheap stuff has been coming down since then.
Sometimes, one should consider a tool a "must have" same as one of the parts for the car and include it in the build cost.
Just my 2 cents.
To the OP.
If you're going to glue on patch panels at the headlight area, make sure they are fitting in a way that they don't need adjustments after gluing. Use tapping screws to install the panels prior to gluing to make sure there are no spots sticking up higher than the surrounding metal. Of coarse the patch will stick up up higher unless it can be installed from the back.
  #17 (permalink)
Old 07-31-2012, 07:10 AM
This project is going to be darn tough without the proper tools and skills. Making "patch panels" as complicated as we are talking would tax the most of us to out limits. Not knowing the skills of the OP I would STILL say searching for replacement fenders is the most realistic way to go.
As far as adhesives and safety and the "right" way and all, it's nonsense in this particular project under these conditions if you ask me.
On the "safety", cars are being "glued" and riveted together at the factory these days at an increasing rate. We are talking 4 star crash tested luxury cars. It is VERY common to see things like frame members bond riveted to the firewalls!
Here is a little test my son did back in fifth or sixth grade. Nicks science project weld vs bond and bolt. click here
BMW has a factory guideline for splicing the frame rail at the radiator support with a "glued" in backing inside the rail. We are talking the component that the bumper bolts to! The FRAME rail, you bond this backing inside the rail without a single bolt, rivet, or holding it on but he glue!
As Pugsy pointed out to make these panels is going to take some serious skills (but a great smaller learning project). It has to be done before it is bonded, there is no way you could be shaping that metal with it bonded on right there, at least that goes against everything I know about the stuff and it will likely fail if that were done.
I am thinking go on to something else on the car and hunt for fenders. At the very least hunt for someone who will mail you the front portions of the fenders and then bond them on.
  #18 (permalink)
Old 07-31-2012, 07:20 AM
Here is a left fender for $50 Click here
And the right is much nicer for $250 click here
  #19 (permalink)
Old 07-31-2012, 09:49 AM
put up or shut up
If I remember correctly that rail insert expands or something? Sounds like you went to the automotive foams and adhesive bonding I-car classes.
  #20 (permalink)
Old 08-05-2012, 06:37 PM
E.T. divided by $ spent= Speed
Thanks Man, I'm gonna contact him.
I had'nt seen anything on ebay for PVs besides small parts.
Only parts house I knew of befor was swedishtreasers in Fayetteville NY. I saved Alan Auto Volvo Service in my Favs.
I'm starting to think I'll slap the existing nose togther just to drive it,as I collect parts to build another nose as cash allows then I'll swap noses.
thanks
removal of pop rivets on my classic grille lakewubcon Garage - Tools 4 04-18-2012 11:55 AM
More patch panels evintho Body - Exterior 2 08-29-2011 08:57 AM
Patch Panels srb23 Body - Exterior 3 09-02-2009 11:43 PM
Patch Panels ARPEE Body - Exterior 2 08-17-2004 10:35 PM
Patch Panels BLOWN 1100 Body - Exterior 1 09-15-2003 08:18 PM
