Popped paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2006, 01:18 PM
Animal's Avatar
Dominators Hot Rod Club
Last journal entry: On the run
Popped paint
I'm sick!
I was drilling a hole in a brace behind the rear valence of my rod when the bit caught and pulled through at lightening speed and hit the valence. this caused the paint (about the size of a penny) to crack and pop off the sheet metal. All the paint is still on the car but obviously lifted.
Is there a fix other than the obvious?
thanks,
Animal
Old 01-15-2006, 01:26 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Not that I know of..sorry for the problem..obviously not knowing what kind of paint job you have it would be hard to recommend any fixes..Mostly involves some sanding and blending to fix something like that..
OMT
Old 01-15-2006, 02:20 PM
Animal's Avatar
Popped Paint
The paint is DuPont Hot Hues with pearl coat.
Old 01-15-2006, 02:35 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Ouch!
that sucks sometimes when I think its going to jerk through like that ill reverse the direction and then go back forward real light with alot of lube.
lot good that dose you now!!
Rob
"SlowRide66"
"Illegitimis non carborundum"
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 12:33 PM
Need advice on a paint job tishmomo Body - Exterior 36 01-15-2008 11:19 AM
Sherman Williams Clear Coat Failing < 3 Years? DeJarnett Body - Exterior 33 12-11-2005 10:39 AM
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 09:41 PM
