Check the firing order again, pay special attention to 5 and 7 they are real easy to mess up as they are next to each other on both ends. You could also have tight valves or something wrong in the ignition system. A bad module can wreak havoc. I would also throw a vacuum gauge on it and check for at least 18 at idle.
Does it only do it when under a load, if so you could have bad wires. Chet |
21 is great, is it steady. An OHM test wont show a leaky wire or a cracked plug they usually show up only under load. If the vacuum is steady I dont think you have tight valves. Have you checked the plugs.
Chet |
Have you checked your timing?
Valve springs are toast.
Okay pulled the valve covers and had my girlfriend crank the engine to check to see if all the rocker arms were moving up and down like they should. They don't, or at least #5 exhaust valve isn't. So I got a flat lobe which crossed my mind before, but really was hoping it was something cheaper and easier.
But I guess it isn't all bad, I really didn't like the heavy grease and grime caked all over the motor (a pet-peeve of mine). So I guess I'll be yanking the engine next week and changing a cam and valve springs/retainers/locks/seals/etc. While the motor is out and partial apart I am going to clean the motor inside and out and then paint it a nice orange (its currently Chevy late '70's blue). I figure for good measure I might as well change the oil pump and the timing chain set too. As far as cam selection I think I am going with the cheap and easy route and buying a Summit cam kit 1102 (.420/.442" lift, 204/214 dur@.050" 112 lsa) for $90. I heard several guys running 1102's in Target 350 crate engine with great results. I am keeping it pretty mild considering this engine is a bone stock late '70's SMOG era 350 with maybe 8.0-8.5:1 compression with unknown amount of miles. I've ran the Summit 1103 cam in a 355 with 9.5:1 compression and it did well. I figure a step down with less compression and it will still do pretty well. What do you guys think 1102 okay? Thanks again. |
| Old popping problem come back to haunt me!! | Siggy_Freud | Engine | 8 | 06-14-2006 01:05 PM |
| I'm going to make a bonfire out of my car | blown69stang | Engine | 36 | 08-22-2005 03:36 PM |
| Jeep 2.5L throttle body to 4L throttle body. | Parisienne66 | Engine | 2 | 07-10-2005 08:35 PM |
| Popping at wide open throttle.... | 383MontecarloSS | Engine | 47 | 02-18-2004 02:40 PM |
| Proper throttle spring placement | willys36@aol.com | Engine | 1 | 11-13-2002 07:19 PM |
