popping at high rpm's - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2006, 05:24 PM
dadstoy70's Avatar
dadstoy70
hi guys,
i'm driving myself crazy trying to figure out why i'm getting a "popping" sound out of the carburetor at high rpm's. i've tried adjusting the carb and timing to a few different settings and it's still there. i've got a sb 400 chevy ( .030 over), edelbrock performer intake, mild cam and a q-jet 750 cfm carb right now. is my carb taking a crap on me??? HELP!!
any help would be appreciated, dave
Old 07-23-2006, 05:55 PM
Steve karch's Avatar
What RPM is this happening. What kind of heads and are the valve springs matched to the cam. It might be the carb but weak valve springs may also cause this.
Old 07-23-2006, 05:59 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by dadstoy70
hi guys,
How did you adjust the carb? Using the idle mixture screws?
How do you know it is carb and not ignition? Fuel delivery?
www.readershotrods.com
Old 07-23-2006, 06:03 PM
dadstoy70's Avatar
dadstoy70
popping
it happens above the 4,000 rpm range. i notice it most when i put my foot in it. i'm running stock heads and a mild cam ( just above a "tow package" cam )
it just started this recently and the only thing i've changed is the spark plugs. i went to shorty plugs because of my headers. i don't know weather to pursue a carb issue or ignition problem.
Old 07-23-2006, 06:05 PM
poncho62's Avatar
Wiki Edits: 5
1/ Running out of gas...........
2/ Valve setting too tight
3/ Cracked/broken rocker arm(s).........bent pushrod
Old 07-23-2006, 06:06 PM
dadstoy70's Avatar
dadstoy70
popping
yes, i used the mixture screws to try and get rid of the popping.
Old 07-23-2006, 06:10 PM
dadstoy70's Avatar
dadstoy70
popping
thanks for all the advice guys. i guess i'll start with process of elimination. the cheapest first of course!
Old 07-23-2006, 07:01 PM
Last journal entry: frame build
Sounds to me like your getting a little valve float. read that weak valve springs or possibly a lifter pumping up.
Old 07-23-2006, 07:02 PM
dadstoy70,
This could be a flat cam also. When the exhaust valve does not open enough to let the burnt gasses out of the cylinder then you will hear a popping coming from the carb. To see if this is the problem take a valve cover off and hook up your timing light to any spark plug. Then start the engine and let it idle. Using the timing light to stop the action of the moving rockers you will see just how much movement each rocker has. With a flat cam lobe the rocker will just sort of wiggle. They do not make any noise because they never open enough to make any noise. And the engine runs ok at lower RPM's because some of the gasses can get out but at higher RPM's these gasses get backed up into the intake and you hear the popping.
Good Luck and Good Hunting
Scholman
Old 07-23-2006, 08:39 PM
E.T. divided by $ spent= Speed
Thats were I would start myself.Are you plugs white after a WOT blast?? If you changed the heat range on the plugs you might need to richen up the carb a bit,with jets and metering rods.
Also if you just added headers from manifolds you might need to ricken up your jets a couple sizes.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
too high rpm help jcdaly Transmission - Rearend 25 01-31-2005 09:03 PM
Dyno Pulls and Blow by at high RPM NoEgoMan100 Engine 5 12-07-2004 12:57 PM
Emissions HELP cutsupreme Engine 33 12-27-2003 09:22 AM
high rpm 55relic General Rodding Tech 1 10-09-2003 02:22 AM
