Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Popping and misfiring
Old 01-27-2013, 08:16 PM
prumora1 prumora1 is offline
not sure how you put Cleveland heads on a Windsor but ok
if your using the same plugs as were on alcohol they are to cold,
if its really high compression could be in detonation, check your plugs for proper firing color.
also if it sat a while depending on cam style could have broken valve spring from setting
