Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Popping and misfiring
Old 01-28-2013, 08:59 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by guy57ford
I have a 351w with alum 351c heads. It has high compression. The motor was run with a single holley on alcohol and ran fine in my race car. The motor has sat for a while. I put it in my 57 with a new holley on pump gas and how it wants to pop and mis. Could it be the pump gas dose not have enough octane to keep from firing on compression? Thanks Guy
Recheck the timing to be sure it didn't move.
Agree w/33Willys77, need more detail- missing under load, w/o a load, etc.
Originally Posted by prumora1 View Post
not sure how you put Cleveland heads on a Windsor but ok
Ford C heads on a W block = Clevor. Takes different intake and valve reliefs, attention to cooling system details. Can make a strong running Ford.
