popping noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2010, 02:40 PM
MosinNagant's Avatar
Chevy Cheetah
popping noise
my 68' chevy truck got a 350 ci. 4 months ago and it did this pop kind of sound. the engine was warmed up and i was accelerating somewhat spiritedly and it hiccupped.what could be the cause of this fuel starvation or too much fuel? it only did it during hard accelleration. any insight will be helpful. thanks.
Old 05-10-2010, 02:53 PM
if it was a back fire out the carb then that is a sign of a lean mixture and/or retarded ignition timing.
a bad or week accelerator pump and low ignition timing are the most common causes for a carb back fire.
Old 05-10-2010, 05:11 PM
I'd guess weak valve springs. Could be other things, but that's my guess. The guys down here that used to run in the bomber-class were famous for engine-backfire whenever they over-rev. They had to run stock engines, and most of them just kept a bunch of un-rebuilt engines on the side, to save money.
'98 cherokee frnt differention popping noise newdad1 Transmission - Rearend 29 08-04-2009 10:48 AM
1991 Chevy truck AC/vent type popping noise flyin99 Electrical 6 07-19-2007 07:39 PM
popping noise capn_crunch4x4 Transmission - Rearend 1 05-19-2006 01:30 PM
popping noise... 97Z28 Suspension - Brakes - Steering 8 02-20-2006 05:05 PM
Overefficient cooling system and popping noise. TVR383 Engine 8 11-09-2005 09:17 PM
